Tranny problems
Old Jan 31, 2003 | 07:49 PM
DaConfusion's Avatar
Default Tranny problems
I have a 95 accord LX with AEM CAI. Whenever the rpms hit around 4500-5000 i hear this loud ringing noise. Some say its the tranny which is damaged...? I have almost 74K on the engine. How much would it cost to covert to manual? Thanks.
Old Feb 1, 2003 | 10:24 AM
iam7head's Avatar
Default Re: Tranny problems (DaConfusion)
auto to manual=1000-1300
run a search
Old Feb 1, 2003 | 10:30 AM
urbanlegend21's Avatar
New User
Default Re: Tranny problems (iam7head)
ringing? can you be a little more specific? like location, tone, speed?
Old Feb 1, 2003 | 11:11 AM
spankey167's Avatar
I've tried searching for that topic as well but with no luck. Your from Socal man, do u know of any shops that do AT to MT swaps? I'm from the 714 area. Thanx
Old Feb 1, 2003 | 06:27 PM
Default Re: Tranny problems (urbanlegend21)
Its like a loud humming noise. When I reach around the 4000+ RPM it starts. It is very audible. Im not sure how else I can decribe it. But doesnt sound too good...
Oh as for location, its coming fromt the engine area... Sorry I dont know how to be more specific. Its just a loud ringing/humming noise that starts and stays until i lower my RPM's.
[Modified by DaConfusion, 3:28 AM 2/2/2003]
Old Feb 1, 2003 | 06:33 PM
briq4's Avatar
Most likely it's the heat shield on the exhaust system, the bolts rust thru and then a rattle develops... you could take it off if you wanted. Next time the car is cool check the heat sheild and see if it has any play in it, it shouldn't. Good luck
Old Feb 1, 2003 | 09:33 PM
Default Re: Tranny problems (briq4)
But that would be a rattling noise right? This noise I am experiencing is like a loud humming, not even close to a rattle. I will try and check tomm tho. Thanks.
Old Feb 1, 2003 | 10:40 PM
iam7head's Avatar
answer to spankey 167..you cant find anyone treat your car better than yourself.
I have the list of what item you need to complete the swap..
let me look for it now..
Old Feb 1, 2003 | 10:45 PM
iam7head's Avatar
https://honda-tech.com/zerothread?id=198357
Old Feb 3, 2003 | 04:40 PM
JonGP3's Avatar
i've seen people with the same problem.. it ended up being they were very low on gear lube in the trany. If you keep driving it like that you will end up messing something up.. so i would suggest getting it checked soon..
Old Feb 3, 2003 | 04:46 PM
Default Re: Tranny problems (JonGP3)
Can you please tell me more about this!? This fix doesnt sound expensive at all I hope!
Old Feb 3, 2003 | 04:54 PM
New User
yeah I would definently say to check your fluid first, a cannot tell if they have a AT fluid dipstick or not
Old Feb 4, 2003 | 07:21 AM
carolinaACCORD's Avatar
yes check the fluid level, atf dipstick is on the tranny, yellow handle.
Old Feb 4, 2003 | 03:43 PM
Default Re: Tranny problems (carolinaACCORD)
The fluid is a little above the XXXXX marks... Does that mean its overfilled?
Old Feb 5, 2003 | 02:45 AM
TypeSH's Avatar
... have you considered the possibility that it is simply normal engine noise, which peaks in that range since peak torque kicks in around 4000-4500 rpm, and peak HP ranges are around 5000rpm?
without a stock resonator (since u have an AEM CAI), the hum is much more noticeable.
[Modified by TypeSH, 11:46 AM 2/5/2003]
Old Feb 5, 2003 | 07:00 AM
briq4's Avatar
Default Re: Tranny problems (TypeSH)
The noise that the heat sheild makes is less of a rattle sound to me, almost sounds like, well not to get really graphic but like someone passing gas. It is the strangest noise from inside the car, and from outside it sounds a little more like a rattle. Just my .02.
Old Feb 5, 2003 | 07:20 PM
People outside my car have noticed it. They make fun of my accord Hmm mabye because they drive Si's and I cant smoke em... But the point is that it really doesnt sound normal. The noise has nothing to do with metal rattling, its like the noise in the movies when like some plane is about to break the sound barrier. I know it sounds corny but im trying to give everyone a good idea. Its a loud humming noise. Thank you all for your thoughtful replies!
Old Feb 6, 2003 | 04:14 PM
scrubachu's Avatar
do you have a system installed in your car? my friends amp had a ringing sound when the rpm's went up past 3 or 4k. other than that try what the other guys posted
Old Feb 7, 2003 | 06:21 PM
Default Re: Tranny problems (scrubachu)
Holy crap I do have a system, well I just removed my 3 ALUM12Q's, but the amp is till plugged in. It makes the noise even when the amp is off, but hmm that is weird.
Old Feb 9, 2003 | 09:37 PM
EuRoBrO's Avatar
Do you really think that you would be able to hear the noise from a system on the outside of your car.
Old Feb 10, 2003 | 04:46 AM
jweller's Avatar
Default Re: Tranny problems (EuRoBrO)
is it definately RPM related? or is it possibly speed related? could be a wheel bearing if it is speed related. I would describe a bad whhel bearing as more of a humming but its hard to describe sounds on the internet it would change tone or pitch when you were in high speed turns, like an exit ramp
[Modified by jweller, 8:48 AM 2/10/2003]
Old Feb 11, 2003 | 12:21 PM
Default Re: Tranny problems (jweller)
It is RPM related because it only comes around 4-5K. And I dont have any hook ups for installing a new tranny, mabye next year when I goto college if my car lasts, I will be majoring in Mechanical Engineering and they should give me access to all the tools. And then I can mabye swap to manual! I guess this problem wont be solved. Its weird that no one else has had this.
Old Feb 11, 2003 | 02:18 PM
ozarkbw's Avatar
It could also be the bearing in the transmission. There is a bearing inside the transmission where the driveaxle connects. It would be a pretty uncommon failure, but it could happen.
Old Feb 11, 2003 | 05:01 PM
RotaryBzzz's Avatar
Default Re: Tranny problems (ozarkbw)
I'd stock out your car one day...put the factory intake back on and see if the noise goes away. Did your car do this before the AEM CAI? There might be something about the install of the AEM (loose / a flap of metal hitting metal at certain engine vibrations / punched lip of metal 'catching air' as it goes by / the list goes on and on).
Alternatively, with that kind of whine, it might be your alternator's bearings going bad if it's so speed related. Although with 76k, that's kinda low. What's the tag on your alternator? "Denso" or is it a freakin' God-Damn GM-sourced "AC-Delco" unit?
I've never heard an auto-tranny make noises since it's just one big hydraulic pump. They just stop working with low-fluid.
dondi_RA6
Jul 8, 2010 08:07 PM
94Gizzer
May 16, 2003 03:59 AM
skafia
Apr 19, 2002 02:02 PM
