how can you tell if your clutch is worn?
if its the stock clutch then maybe its going. is the engine stock? after 180k the clutch should be replaced. you can tell if its going a few ways. if you ease out the clutch and the car doesnt seem to catch like it should then it should be replaced.
mayb i should replace it.... is it ok to use 6 puck act on my stock pressure plate?
my car chirps second and i have less power than an si hatch.
but then again, my car was driven by a male nurse for 45K miles, lol.
its time for a new clutch. stay away from a 6/4/3 puck racing clutches. check out the ACT heavy duty.
(what's wrong with a 3/4/6 puck racing style clutch? ( i dont own one, nor am i looking for one, just wondering the differences between them all)
I think I remember reading of one test in which you drive up a steep incline, put it in 5th and floor it to see if it slips. Perhaps someone else will chime in on this test.
usually to tell if a clutch is worn is when the clutch engages really high,..like when you put the car in first and ease off the clutch just a tad,..you can feel the car go forward just a little bit,..if you have to ease off the pedal almost all the way this is a sign that the clutch is worn,..when people say slipping,..then mean if you are getting on it and the revs go up but the car is hardly picking up,...i have heard you can smell a clutch slipping
i have a clutch masters stage 3 and it engages high but thats what aftermarket clutches are suppose to do,..and yes mine doesnt have a spring hub,..it does catch violent,..the shock can hurt your syncros because there is no spring to absorb the shock ,...it could chip a tooth on the syncros and what not
and you should not be worried about chirping second,..chirping second just means your not shifting right,..but it sounds cool
http://www.clutchcityonline.com
If you don't plan on racing the car, get a cheap OEM Exedy kit. If you do, get something from ACT or CM, choose your poison.
This is how to tell if your clutch is worn. If the tachometer still goes up but your mph doesn't move, your clutch is bad. With my car, 220k miles on a 90 Integra and still on the stock clutch, it slips like a bitch.
[Modified by fOmaNPu, 2:40 PM 2/1/2003]
Different clutches will have slightly varied engagement points, but in general the wear of the clutch will not affect its engagement point.
The most obvious signs is a slipping clutch, when you give the car gas and the engine revs but the car goes no faster.
Guest
Posts: n/a
What i was told was to rev it to 5000 and dump the clutch if it jerks you hard it is still ok but if it just jerks a little or not at all it should be replaced
[Modified by autoxdelsol, 11:26 PM 2/1/2003]
uhmm, are you sure about that? Most aftermarket clutches grab LOWER than the stock clutch. My OEM clutch grabbed at about 50-55% off the floor. my ACT HDSS clutch kit grabs at about 30-40% off the floor, depending on conditions.
and spoon hybrid what your doing is power shifting,...i see no point in power shifting,..it only knocks off a couple tenths of a second off your 1/4 mile time,...but it could hurt your tranny and clutch also,...but im not hating,..if this is how you race then keep with it,..whatever your comfortable with,...and people tend to get a better and sometimes louder chirp when they power shift
it will start to stick and not grab or grab too much. As for what to go with, I talked to a guy at ACT when I was going to get an account with them. I was told that for Stock motor, that Stage 1 was prime choice, but that for street and strip stage 2 would be nice..
i hav a 98 coupe and its real tuff to start off in first hav to hold the clutch till i get movin a bit and usually dont shift till 3k rpm, and no chrip goin to second...so sounds like i neeed a clutch too...anyone agree? or is it not supposed to chrip and d16 weak so tuff to start off =[ hope its the clutch
oh yeh cars stock poor tires, i also thot that 2nd gear chrip was due to trannys efficency to transfer power to next gear
[Modified by dash0n, 11:51 AM 2/2/2003]
the best wat to test your clutch to see if its bad is too set the ebrake put it in 3 gear and then go just if you were pulling away from a light. if the car stales then your clutch is still ok if it continues to run wiht the clutch all the way out u need a new clutch. also if you shift hard and the the car engages but the rpms drop thats also another sing
