96-00 Civic HB. Leaking Hatch.........where does it come from ????
Old Jan 31, 2003 | 05:51 PM
hulkhb's Avatar
Default 96-00 Civic HB. Leaking Hatch.........where does it come from ????
ok so i go down to see a buddy of mine i havn't seen in a while. And we were BS'n about our cars, 98 civic HB's. and he tells me he has water in his spare tire well. Today was the first time in about a month i drove my car and i go to look in my spare tire well and BOOM theres about a 1/2" of water sitting in there. We live in Washington so yea it rains a bit here. So where does the water come from ?
i havn't gone out and looked for a hole or anything yet just wanted to check with anyone else to see where it comes from and if anyone else has the same deal.
thanks in advance. pics would be good if theres a hole i need to fill up.
Old Jan 31, 2003 | 05:59 PM
black2kcivic's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (hulkhb)
I have a leaky hatch also, it looks like it comes from the drivers side of the hatch... that sucks **** too because my hatch leaks like a damn sive. In a related story my back drivers side tail light also leaks.
Old Jan 31, 2003 | 06:03 PM
rathead's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (black2kcivic)
check the gas tank popper, behind the inside pannel you will be able to see the cable for the popper. check for leakage. there is a gasket for the popper that you will see when your gas tank door is open. i have seen this before more than once
Old Jan 31, 2003 | 06:24 PM
VSMHatcH's Avatar
bump
i have the same problem
talked to the dealership they said its the taillight
and its going to cost me $100 to fix...if that is the problem
Old Jan 31, 2003 | 06:27 PM
TRENDSETTLER's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (VSMHatcH)
i have the same leaky problem...can find where its comin from though...im gonna check the gas popper thing now though
Old Jan 31, 2003 | 06:52 PM
hulkhb's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (TRENDSETTLER)
well i am gona go out and check it out, good thing my rear Hatch is all stripped.
my buddy said that he just left it and now he has a mildew smell , YUMM
time to get a tube a silicon and go to town
Old Jan 31, 2003 | 07:00 PM
-Gambit-'s Avatar
the water comes from tail lights, you need to seal all around the tail lights to stop it. I put silicon around the top of my taillights and it stopped it
Old Jan 31, 2003 | 07:48 PM
confidence's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (gambit33)
dead on man. it's the tail lights. gambit, can you post pics of where you put the silicon? i really want to know. i am sick of having to towl out my car every 2 days.
Old Jan 31, 2003 | 07:49 PM
jonas's Avatar
mine used to do it..but it stopped all of a sudden *shrug*
Old Jan 31, 2003 | 08:24 PM
hulkhb's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (jonas)
lol, good thing for you jonus, it was Zol i was talking about in the first post above, he should be calling you about the meet on the 22nd if he doesn't work.
Thanks for the info guys
Old Jan 31, 2003 | 08:37 PM
-Gambit-'s Avatar
well i dont have a pic, but when you pop your hatch, you will see the tops of the taillights where they meet the body. I just it all around where the plastic met up with the body
Old Feb 1, 2003 | 06:49 AM
96BlackHB's Avatar
Mine used to leak. I put down the back seat and pulled everyting out of the hatch (carpet, spare tire cover, spare tire). I sat on the folded seats and my brother sprayed water all over the hatch and rear of the car. After a couple of minutes water started coming in througth the passenger side tail light. I replaced the foam gasket and sealed the tail light with silicone and haven't had a problem in 2 1/2 years. HTH.
Old Feb 1, 2003 | 08:27 AM
dwnthehatch's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (96BlackHB)
Taillight seals.
Old Feb 1, 2003 | 11:07 AM
thinkbrianthink's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (dwnthehatch)
just to reiterate (sp?) the point already proven its the tail lights. if you pull out the tail light you will see that there is a foam gasket between the tail light and the car. i used weather strip glue in between the gasket and the car and also inbetween the gasket and the tail light. no problems since. weather strip glue is a little much in my opinion but i had it on hand and didnt feel like going to the store for anything else. any light silicone sealant should do though.
Old Feb 1, 2003 | 11:17 AM
SprayinCX's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (thinkbrianthink v.1)
mine leaks like a ****, so i just drilled two little holes for it to drain out of.
GARBhatch.'s Avatar
same here...I heard of this happening a lot on them. it only started when i put the red/clears in mine tho... and always seems to be the passengers side when i do hear about it happening.. wierd.. took them out and adjusted the gasket then siliconed it, went through the winter nicely so far.
Old Feb 1, 2003 | 11:42 AM
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (98Hatch00)
Thanks for the info, I am going to check my tail lights when I get home from work.
Old Feb 1, 2003 | 12:06 PM
AllMotorHB's Avatar
I've noticed lately that mine is also leaking. Seems like most of the 96-00 hatchbacks have this problem. I wonder if theirs a recall on it or something.
Old Feb 1, 2003 | 01:33 PM
Sucka Free's Avatar
New User
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (AllMotorHB)
if it indeed your tail lights,
you can always go to the dealer and get new tail light gasket sponge things.
or you can do what i did.
just get some silicone.
put some of the glue on the seal and screw the light back on,
should be fine after that.
Old Feb 1, 2003 | 02:29 PM
2.0L EK's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (Sucka Free)
Same problem!!!
Replaced the tail light gaskets, and rear hatch seal but water still ends up in there!
I'll check the gas tank thing next time I was the car.
Old Feb 1, 2003 | 03:03 PM
shonnys92si's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (2kTypeRHatch)
i have the same problem happening in my 92si
Old Feb 1, 2003 | 03:06 PM
hondaki33er's Avatar
Default Re: 96-00 Civic HB. Leaking Hatch.........where does it come from ???? (shonnys92si)
speaking of water in tail lights, anyone know how to take them apart and clean them out? the tails on my EF have had water in them so long they are now discolored and have rust or something inside them.
crr
Jul 19, 2021 11:25 AM
StayKrafty
Oct 29, 2008 10:14 PM
user 98292739
12
May 1, 2008 08:48 AM
Riced-EL
Jan 8, 2007 10:09 AM
EL Vap133
Jan 5, 2006 07:03 AM
