Simple Electricity question
Old Jan 31, 2003 | 05:24 PM
Bantam's Avatar
2nd Coolest Person in DFW
Default Simple Electricity question
Hey, I am looking for a place that is easily accessible for wiring to find a positive 12 volts that Is activated by the ignition Thanks alot for any help. Soon preferably!!
Old Jan 31, 2003 | 05:25 PM
iam7head's Avatar
Default Re: Simple Electricity question (tharptroy)
pretty much alot of the power in the car are 12v...for example
signal light.
you can do it direct with the battery and activitate it by hacking into the steering wheels column.
Old Jan 31, 2003 | 05:31 PM
Bantam's Avatar
Default Re: Simple Electricity question (iam7head)
Okay, I think I catch what you are saying. Thanks Ill go try it.
Old Jan 31, 2003 | 05:36 PM
Stew Pidasso's Avatar
Well I'm going to use my psychic ability and guess that you have a 4th or 5th gen Accord because I can't find anywhere that specifies this.
What your going to be looking for is a thick (10ga) black wire with a yellow stripe. You will find it under the column going towards the fuse box in that thick bunck of wires. Poke it with a test light to verify that you have the correct one. (Or use a multimeter.)
Old Jan 31, 2003 | 05:39 PM
iam7head's Avatar
Default Re: Simple Electricity question (Stew Pidasso)
go do a search on a s2000 push start wire up.
most of the ricer site have some sort of diagram from that you can figure out
where to slice and dice.
Old Jan 31, 2003 | 06:29 PM
Bantam's Avatar
Well, stew you are a badass because I have a 4th gen and I'll look for the wire tomorrow thanks.
Old Jan 31, 2003 | 06:55 PM
I looked into my crystal ball...
Old Feb 1, 2003 | 04:45 AM
Bantam's Avatar
hey stu, Ive found the wire it is in the cabin though and I have only a few inches of spare wire I can work with, should I cut it and put the wire that I need fed, along with both ends of the Black/yellow wire into a wire nut and call it done?
Thanks
[Modified by tharptroy, 1:47 PM 2/1/2003]
Old Feb 1, 2003 | 05:33 AM
You can do that but I would recommend a good butt connector for in the car. Those wire nuts have a tendency to vibrate loose over time and it could cause problems.
Edit: It's a big thick wire correct?
[Modified by Stew Pidasso, 9:33 AM 2/1/2003]
Old Feb 1, 2003 | 06:04 AM
jweller's Avatar
better yet would be to solder the connection, especially if it's the ignition you're fooling with
Old Feb 1, 2003 | 04:27 PM
Bantam's Avatar
yeah, it's a big thick wire...I have it wire-nutted for now and I ahve power to the switch ...When I get some time I'll do it right...Everything is going as planned except I forgot to hook up the fuel-pressure cut off thing On my NOS kit so it didn't work on my 1st try, maybe I'll give it another go tonight
SoB NiG
21
Jun 1, 2011 01:01 PM
ctownintegra
Jul 18, 2006 08:35 AM
oryanh
Mar 26, 2003 02:00 PM
Jeff_G
Oct 5, 2002 05:41 PM
