who all welds the chambers on there heads?
Old Jan 31, 2003 | 10:26 AM
eddiecut's Avatar
Default who all welds the chambers on there heads?
does it really raise your compression up 1 point??
Old Jan 31, 2003 | 10:53 AM
ExospeedAMcrx's Avatar
Default Re: who all welds the chambers on there heads? (eddiecut)
edit.....
[Modified by exospeedAMcrx, 12:51 AM 2/2/2003]
Old Jan 31, 2003 | 03:37 PM
Suprdave's Avatar
I would only think of if you were totally reworking the ports and going all-out ona head. Definately not for a street-car...you'll need custom pistons, among other things. You should consult a quality head porter.
Suprdave
Old Jan 31, 2003 | 08:32 PM
TREVER's Avatar
Default Re: who all welds the chambers on there heads? (Suprdave)
welding=heat=warpage=misaligned cam bearinings
Old Jan 31, 2003 | 11:29 PM
eddiecut's Avatar
Default Re: who all welds the chambers on there heads? (TREVER)
thanks for the replies guys.
Old Feb 1, 2003 | 12:32 AM
miller's Avatar
i dont know it has been done with great success before.
Old Feb 2, 2003 | 02:24 PM
Drag R's Avatar
Doesn't DPR reshape chambers i know a couple people running them as daily drivers...
STAGE VI
Stage V plus...
Combustion Chambers Welded & Reshaped, (clover-leaf pent-roof design)
Intake Valves Lightened
Rocker Arms Lightened
Fully Balenced & Blueprinted
Includes Valve Spring Shims as Needed
Starting at $1950.00 USD (Labor Only)
nick
Old Feb 5, 2003 | 08:17 PM
BudaKai's Avatar
Yes it's a very bad idea. You have to account for the expansion rates on the filler, and if you know anything about welding aluminum it's not veryeasy. I wouldn't suggest it at all.
Old Feb 6, 2003 | 02:47 PM
HEAD's Avatar
this could be done safely but it would require alot of work, time , and money and for a daily driver I'd suggest spending your money else where. As far as raising the compression a full point that would depend on the individual doing it, how big they made the clover shape and how much they surfaced the head afterwards,. I don't think you would have to worry about head worpage because because it would take an extreme amount of heat to do so from the deck but I would put valve seats in the head afterward because they could move around from the heat, DEFINITLY find someone who has a tig welder and knows what your looking to do with your head and has experience doing it
ol'rex
May 6, 2006 11:37 PM
Full Race A6
12
Sep 23, 2004 11:20 PM
TodaCivic
Jun 8, 2004 12:38 PM
H22CL
Apr 24, 2004 09:31 PM
DYI01
Mar 9, 2002 02:40 PM
