JDM b18c + usdm type r head + usdm type r pistons = valves hitting pistons?????
Old Jan 31, 2003 | 06:49 AM
bodydropranger's Avatar
Default JDM b18c + usdm type r head + usdm type r pistons = valves hitting pistons?????
we are in the process of building a NA b18c motor. it has usdm type r pistons, usdm type r head, and a mugen head gasket. will this combo work or did i get some bad info. we are having clearance issues when we turn every thing to top dead center
can anyone verify the setup
Old Jan 31, 2003 | 07:14 AM
Extreme's Avatar
Default Re: JDM b18c + usdm type r head + usdm type r pistons = valves hitting pistons????? (bodydropranger)
Poorman itr combo shouldn't be a problem. Is your cam set @ 0 deg (straight up)?
You may want to redo you timing belt install and make sure to line up the cam/crank properly per Helm.
down_the_hatch
19
Dec 9, 2010 01:44 PM
iheartmyctr
Jul 3, 2008 07:01 AM
KURUPTinc
Aug 7, 2007 09:54 PM
RyosukeFC3s
Apr 30, 2006 08:48 AM
Project_SOHC_EX
May 31, 2003 10:38 AM
