crappy brake question
Old Jan 31, 2003 | 01:35 AM
ion_four's Avatar
Default crappy brake question
So, I'm in the midst of the (seemingly) never-ending integra rear disc swap, on my 93 Civic EX Coupe...I can't get the rear caliper piston to 'twist in' to accomodate the new pads. Is it possible to just compress it in with a C-clamp, or atleast get it started this way? These calipers are from a boneyard and may be crud, but I'd atleast try to see if I can't salvage them.
Any thoughts?
Old Jan 31, 2003 | 05:59 AM
1BlackHatch's Avatar
Default Re: crappy brake question (ion_four)
I know for sure that you can't use a C clamp. The caliper is designed to twist in. Use some brake cleaner to loosen it up a little and keep trying.
[Modified by 1BlackHatch, 3:00 PM 1/31/2003]
Old Jan 31, 2003 | 01:52 PM
ion_four's Avatar
Default Re: crappy brake question (1BlackHatch)
that sucks man...think that bum might be able to give me a hand? haha
anyone else have any suggestions?
Old Jan 31, 2003 | 05:48 PM
the DR.'s Avatar
thats the only way i can think of, they make a tool for it, try twisting in one direction then the other to see if you can break it loose or something
Old Jan 31, 2003 | 07:49 PM
tominos's Avatar
aren't you supposed to use a c clamp to push the piston back into the bore, or are you talking about somthing else?
Old Feb 2, 2003 | 01:01 AM
ion_four's Avatar
Default Re: crappy brake question (tominos)
it seems you can only use a c-clamp on the front calipers. I am going to attach the cailpers to the brackets and pump the brakes and hope it will get them freed-up. Is this a good idea? Any other thoughts on how to get them moving?
Somewhat related...almost all, if not all, of the fluid drained out of my mastercylinder...do I have to take it off and bench bleed it, or can I just fill it up and bleed the whole system like normal to flush it out? I also swapped out the proportioning valve, but that shouldn't matter...
nicko360
Sep 10, 2007 09:13 PM
leviq
Jul 7, 2007 08:28 AM
ITR198
Nov 5, 2005 08:25 PM
ken
Jul 3, 2002 08:00 PM
wickedxbo1
Dec 30, 2001 07:51 PM
