ls vtec
say i use a b16a crank and use rods made for a ctr motor(b16b) what kinda output would i have turbo that motor in a b18b block worth it not worth it stupid idea good idea any suggestions i would appreciate it thanks
b18b-block
b16a-crank
b16b-rods?
9.1-1froged -pistons???
make a good turbo motor???
[Modified by b18vtec, 5:29 AM 1/31/2003]
b18b-block
b16a-crank
b16b-rods?
one of the main reasons for ls/vtec is for the torque...
slapping a b16 crank would defeat the purpose.....
stick with the ls crank + block....
or else just get a vtec block and don't even mess with ls/vtec
first off the journals on the b16a crankshaft is not the same as the big end bore size on the b16b rods. you better check your clearences before something catastrophic happens.
whiteknightef
Mar 30, 2004 10:00 AM
