compression psi?
would anyone happen to know the max value of the compression psi for the d15b7? the chilton manual doesnt seem to have it, only the ratio (9.2:1) so any help would be greatly appreciated. i want to see how good she is yet after 161,000
it depends if you test it cold or warm. As long as the cylinders aren't more than +- 10 psi of the median, I wouldn't worry at all!
Edit- like if it's 190-195-190-160...then you know you have a problem
[Modified by Emerica, 10:21 PM 2/1/2003]
What do you mean max. pressure in PSI?
Do you mean the maximum compression ratio, which has nothing to do with PSI?
Do you mean the maximum amount of boost in PSI that the stock engine can handle?
brent_G
Oct 12, 2003 12:15 AM
