shift linkage tips?
Old Jan 30, 2003 | 07:39 PM
made in JAPAN's Avatar
Default shift linkage tips?
in a few days in going to be pulling my motor out and i heard the removing the shift linkage pin is a pain in the *****....does anybody have any tips on doing this?
Old Jan 30, 2003 | 08:18 PM
Pengo's Avatar
Default Re: shift linkage tips? (made in JAPAN)
i like to drop the end that is attached to the shifter and remove the engine/tranny/shift linkage altogether. then you can sit down and comfortably take your time to punch out that pin. much better then laying under the car, esp when your doing it by hand with not pneumatic tools or compressor. good luck
-alan
Old Jan 30, 2003 | 08:25 PM
Agent#ONE's Avatar
Default Re: shift linkage tips? (Pengo)
easy
take a 12mm honda bolt long enough to go thru the rod.
small sledge/malet take seconds
your welcome
Old Jan 30, 2003 | 10:07 PM
tilt's Avatar
Default Re: shift linkage tips? (Agent#1)
yep. disconnect the shift linkage at the shifter end
Old Jan 31, 2003 | 06:28 AM
Default Re: shift linkage tips? (tilt)
does the pin need to come out from the top or bottom (do i hammer it down or up?)
Old Jan 31, 2003 | 07:16 AM
Agent#ONE's Avatar
crawl underneath, hold the bolt steady to the pin, and give it a couple whacks from the bottom, should come out with ease....i think it was designed to take the honda `12mm bolt, its a perfect punch for this situation
when i first started doing this stuff, id spend an hour at least on some linkages, trying to use whatever i could...then one day, i undid the 12mm from the other linkage rod, it hit me in the eyeball, then i had a great frikin idea and trued that bolt, what do ya know
it worked.
Old Jan 31, 2003 | 08:22 PM
integra6650's Avatar
ah crap i went to sears to get a punch didn;t have size so i sat there and drilled it out took far longer than this 3 seconds im hearing about
also now that its going back in i bought a double flare tool has anyone done this is it hard
8Gomer9
Aug 21, 2009 09:46 AM
umair
Mar 27, 2009 03:27 PM
ALLMOTOR CRX
11
Mar 29, 2007 07:34 AM
honda4674
Jun 24, 2006 12:45 AM
Unjockable
Apr 24, 2002 10:13 PM
