4040 proportioning valve
How can I tell if it is a 4040 proportioning valve, and which one will work best with my car, it is a 92-95 civic lx.
I heard a 95 integra rs one will work, but when I was at the wrecker it was to hard to tell what kind of integra it was..... any pics of the right proportioning valve would be good to.
Unless you have upgraded to bigger brakes, and/or rear disk brakes, you shouldn't mess with it.
[Modified by ChiBoy, 11:01 PM 1/30/2003]
thanks, so what type of proportioning valve do you think I should use then with my setup of GSR front/rear compared to my oringinal disc/drum setup?
[Modified by eg6si, 9:01 AM 2/1/2003]
Sorry to jack your threat
I just did a brake swap from a 95 ls to a 92 si, for both front and rear, ls mc and booster,
One thing i forgot to take out is the proportioning valve from the integra, so will the one in the eg work with the brake system?
,I just did a brake swap from a 95 ls to a 92 si, for both front and rear, ls mc and booster,
you'll do fine with a 30/30 prop valve...i'ved done this gsr brake upgrade on four civics now.
