Felpro Headgasket.....
Old Jan 30, 2003 | 03:10 PM
hanginlow's Avatar
Default Felpro Headgasket.....
Anyone use this before? Does anyone know if this is comparable to a stock gasket? This one is 5 layer metal, i thought that stock was 3....help please
Old Jan 30, 2003 | 03:22 PM
niedejb's Avatar
Default Re: Felpro Headgasket..... (boostedf22)
I got an OEM to use with my GE block. They only recommend stock head gaskets.
Why do you want to use felpro?
Old Jan 30, 2003 | 03:52 PM
hanginlow's Avatar
Default Re: Felpro Headgasket..... (niedejb)
I went to autozone and they had it there for like 70 bucks, so i basically want to know if it will be fine to use it. I need something smaller than whats on mine now, and they said at autozone that this is an aftermarket oem, so i dont know. I dont' want to take it out and have it not fit because you can't return it if it is opened. So, any suggestions.
[Modified by boostedf22, 1:08 AM 1/31/2003]
Old Jan 30, 2003 | 04:07 PM
niedejb's Avatar
I paid $55 for mine from http://www.hondaautomotiveparts.com/
Old Jan 30, 2003 | 04:10 PM
hanginlow's Avatar
is it comparable to stock? and where exactally did you find it on here...because i had looked on here and all they had was the gasket kit. Thanks
Greg
Old Jan 30, 2003 | 04:12 PM
hanginlow's Avatar
is it comparable to stock, because i have the same engine as you? and where exactally did you find it on here...because i had looked on here and all they had was the gasket kit. Thanks
Greg
Old Jan 30, 2003 | 05:32 PM
slomofo's Avatar
GDD Member
I got a fel-pro last july, last night I checked my oil and saw bubbles on the dipstick. My fault for buying a headgasket for $19.99.
Old Jan 30, 2003 | 06:04 PM
niedejb's Avatar
Default Re: Felpro Headgasket..... (slomofo)
Its under CYLINDER HEAD (2)
Its $58 dollars...sorry about that.
Old Jan 31, 2003 | 04:25 AM
hanginlow's Avatar
What brand headgasket was it? Was it an OEM gasket? Thanks for the help.
Greg
Old Jan 31, 2003 | 09:25 AM
niedejb's Avatar
All parts are OEM from that site (to my knowledge)
teamworxek9
Jul 31, 2009 02:01 PM
CivSiClone_96
Mar 31, 2009 07:53 AM
ICeDoUt
Mar 23, 2005 06:57 PM
hondaapi
Oct 20, 2004 09:42 PM
boostedr
Oct 17, 2003 09:38 AM
