why valve adjustment?
Old Jan 30, 2003 | 01:44 PM
SamC's Avatar
Default why valve adjustment?
Can some one explain to me why do we need to a valve adjustment? I mean what happend to the car when the valves clearance are off, either too tight or loose? how does it affect the car? Thanks
Old Jan 30, 2003 | 01:50 PM
ALLmotorCRX's Avatar
Default Re: why valve adjustment? (SamC)
Ill explain, its because YOU NEED ONE after a certain amount of miles. u dont need one, its just a matter of how much u care about ur motor.
Old Jan 30, 2003 | 02:08 PM
speedymon's Avatar
Default Re: why valve adjustment? (ALLmotorCRX)
Over time the clearance between the cam lobe and rocker arm gets out of spec. If the gap is above specs then the cam lobe is not pushing the rocker arm, which in turn pushes the valve all the way down. If the valve doesn't open fully the combustion chamber doesn't fill with all the air it can. Less air = less power.
Old Jan 30, 2003 | 02:21 PM
lazy bum shaughn's Avatar
Default Re: why valve adjustment? (speedymon)
Nice. How often should you adjust your valves? Is it hard?
Old Jan 30, 2003 | 03:06 PM
SamC's Avatar
Thanks...
Old Jan 30, 2003 | 03:34 PM
bartek_b's Avatar
Default Re: why valve adjustment? (lazy bum shaughn)
I am interested in knowing too. I think you might need to take them out and re-install them?? just a guess.
Old Jan 30, 2003 | 04:06 PM
Turbo Dreams's Avatar
Default Re: why valve adjustment? (gr8gribbs)
If you stay in the high RPM's alot then you need to do it sooner. Also, if they need to be adjusted the motor will make louder clicking noises. Make sure the engine is cold when you adjust them too.
Old Jan 30, 2003 | 04:16 PM
Regular Series's Avatar
Default Re: why valve adjustment? (Turbo Dreams)
How loud are the tappets on a B-series engine? Mine are quite chattery when the engine is cold. They are still audible after the engine warms up, but only just so. I had them adjusted ~14k miles ago so I doubt they're out of spec, but I'm just curious.
Old Jan 30, 2003 | 07:47 PM
Lord Helmet's Avatar
Default Re: why valve adjustment? (mugen85r)
LOL no, you insert a feeler gauge between the rocker arm and the valve retainer. you adjust it by tighten the screw or loosen the screw. I forgot the specs but for my car with a d16z6 I set mind at .007 on intake and .009 on the exhuast side (thats for the zex cam stage 2) still chatterly but that's expected from a performance camshaft.
Old Jan 30, 2003 | 07:59 PM
illusion's Avatar
Your supposed to adjust twice.... Cold, let run and cool down, and adjust again.
who says this? the helms and any other resource that ive checked makes no mention of it...
Old Jan 30, 2003 | 09:27 PM
tevbax's Avatar
Default Re: why valve adjustment? (illusion)
Adjust them twice..... no matter what the manual says. Better to be safe then sorry. Also, the second time around, you can see how close your adjustment was.... so you know if you should have that next drink or not
Mike
Old Jan 31, 2003 | 04:58 AM
illusion's Avatar
Default Re: why valve adjustment? (tevbax)
hrmmmmmm
Old Jan 31, 2003 | 06:13 AM
Si's Avatar
Si
I think you need to have the valves adjusted every 30k miles, honda engines with a lot of miles make a ticking sound if the valves haven't been adjusted.
Some info here:
http://www.overboost.com/story.asp?id=126
Old Jan 31, 2003 | 06:50 AM
tpr's Avatar
tpr
Default Re: why valve adjustment? (RedSi99)
Nobody has addressed the real issue here. The valve and seat wear slightly reducing the clearance over time. If that clearance gets so small or non existent the valves will remain open when they should be sealed. On the exhaust side it will burn the valve. On the intake side the flame front will be allowed to leak into the intake possible fire/explosion.
Conversely if the cam/rocker arm wear then the valves get noisy and do not open as fully as they might if properly adjusted. It is better for them to be noisy than than too quiet (It won't burn the valves).
Old Jan 31, 2003 | 07:01 PM
MrJasey's Avatar
u need valve adjustment to make sure they arent too lose or too tight
if u remove part of the valve train u should adjust them or for the service intervals
because they will stay open too long and get burnt and that sucks
also u have o do it when it is cold beacuse if u take apart your head when it is still warm, then it can become warped and that is not a good thing
[Modified by MrJasey, 4:04 AM 2/1/2003]
Old Feb 1, 2003 | 08:47 AM
speedymon's Avatar
Default Re: why valve adjustment? (MrJasey)
There is no taking apart your head for a valve adjustment only the valve cover. The reason you wait till it's absolutely cold is so that the valve clearances do not change while you're adjusting them. Metal expands and contracts when heated and cooled.
garyc17
May 4, 2007 08:29 PM
NA JDM GSR
Oct 17, 2006 10:50 PM
KURUPTinc
Jul 2, 2005 06:12 PM
95gsr
Apr 8, 2003 07:20 AM
Cow
Jun 26, 2002 04:12 PM
