New Clutch = 1st gear shuddering
Recently installed Clutchmasters stage 3 and aluminum flywheel. Now in first gear when I take off the car has a slight shudder or shaking. When I rev it up to about 3k then drive everything is fine.
My question is this something normal with this type of clutch and flywheel combo or is there something else wrong? I am about 300 miles into the break in period with this clutch.
Thanks
[Modified by JediGSR, 2:27 PM 1/30/2003]
Thanks
have you been good on the clutch during the break in? Was everything cleaned up with brake cleaner (flywheel and pressure plate) or did the clutch get some grease on it? I'm just thinking of ideas on why it would shudder.
well mine does that too (ACT)...and a coulple of other people said they were going through the same thing and said it was normal for an high performance clutch......
These guys are right, its not first gear. It's just clutch chatter. Its really nothing to worry about, just get used to it.
Thanks for the info, at least I can rest knowing its nothing serious. It is very annoying though but your right I'll have to live with it.
yea the clutch is chattering, not good for it. do all u can to not do it. just dump the clutch and burn out if u have to, but dont let it chatter like that, its a bad way to fubar up the trans not to mention the clutch and flywheel
Some times is chatter and sometimes its motor mounts. If its chatter you must just learn how to work the clutch in smoother. Sometimes with REAL grippy clutches, stock motor mounts tend to break depending on you whp. Just do a check.
carbone
Transmission & Drivetrain
Oct 8, 2015 09:18 PM
an2ny888
Sep 7, 2010 08:58 PM
