stroke on f23a
anyone know what the stroke of a f23 is. i'm trying to calculate the displacement of a h22 block bored to 89mm with a f23 crank. i dont know if this is similar to using the h23 cranks or not but anyone see any reliability issues with that setup if the whole bottom end is balance?
thanks
thanks
F22 B: 85 S: 95
F23 B: 86 S: 87
F23 B: 86 S: 87
am i doing something wrong? i'm calculating it using the following equation:
displacement = raidus of bore squared x pi x 4, then convert to L from by dividing by 1000000
[Modified by areyouasian, 3:22 PM 1/30/2003]
I believe the f23 cranks have a 97mm stroke. I am looking into this as well for my new stroker cranks.
F22 B: 85 S: 95
F23 B: 86 S: 87
H22 B: 87 S: 90.7
H23 B: 87 S: 95
F23 B: 86 S: 87
H22 B: 87 S: 90.7
H23 B: 87 S: 95
and you get 87mm bore with a 90mm stroke and you get 2.3 i was just thinking if you put the crank in a h23 on a stock bore you could get a 2.4 or at least the #'s will round off to a 2.4 but i must me wrong
acutally 2.4 is about right with a 88.5mm bore, its just that you said 2.5 earlier so i didnt know how you got that.
[Modified by areyouasian, 10:18 PM 1/30/2003]
since you have experience with stroking engines, would do you predict the reliability with the f23 crank be better, worst, or the same as with puttin in a f22 or h23 crank into an h22?
fastludeh22
Nov 20, 2003 09:08 AM
