rebuilt engine cuts off when coming to a stop
Old Jan 30, 2003 | 01:23 AM
MebaneSi's Avatar
New User
Default rebuilt engine cuts off when coming to a stop
I need some assistance in troubleshooting why my engine cuts off when coming to a stop. First let me give you some background and details to help you. I just finished an all-motor performance rebuild on my 2000 Civic Si and I now have approx 1100 miles on the rebuilt engine. The changes are listed below. Some things that I have done to try to fix the problem are 1. Advanced the timing to 18 degrees BTDC 2. Adjusted and set idle to Honda’s specs. 3. Using NGK plugs PFR6G-13 and verified gap to be within specs. The engine dies only when I come to a stop, and occurs 80% of the time. I can be going down the road (no stopping) and disengage the clutch making the engine fall to idle. When I do this the engine stays running every time. Any one have any ideas. Your help is greatly appreciated.
Thank you,
Michael
1. Lightened flywheel
2. Knife-edged the crank shaft
3. All new bottom end bearings and seals
4. Eagle rods and Aries pistons with Total Seal rings with a final CR of 10.8:1
5. Aggressive head port & polish
6. Skunk2 valve springs and Ti retainers
7. AEM under drive pulleys
8. Gutted cat
9. O2 simulator
Old Jan 30, 2003 | 04:08 AM
CivicEK.PDX's Avatar
Default Re: rebuilt engine cuts off when coming to a stop (MebaneSi)
Its problay cause your bottomend is too damn light. The B16 crank is already tiny compared to a GSR and the Grand daddy of the all the ITR. If you sat all 3 cranks next to each other you notice a HUGE difference in size and weight.
WojtekG
Sep 13, 2018 07:15 AM
GSE980
Jul 29, 2007 04:58 PM
globy123
Jun 15, 2007 12:45 PM
RABBIT9
Apr 22, 2003 02:13 PM
oldbeefcake
Mar 19, 2002 07:02 PM
