aftermarket gears for B-series cable trannies
Old Jan 29, 2003 | 05:55 PM
Taloola's Avatar
Default aftermarket gears for B-series cable trannies
looking for better gearing on my y1 tranny. any help?
[Modified by gokoolFL, 2:55 AM 1/30/2003]
Old Jan 29, 2003 | 09:48 PM
turbohonda's Avatar
Default Re: aftermarket gears for B-series cable trannies (gokoolFL)
Get an S1 or J1.
Old Jan 29, 2003 | 09:56 PM
BudaKai's Avatar
Default Re: aftermarket gears for B-series cable trannies (10s_ALLMotor)
I want to know also. Cable tranies are cheaper and better for racing IMO.
Old Jan 29, 2003 | 11:10 PM
DLB1994's Avatar
Default Re: aftermarket gears for B-series cable trannies (tzsir)
who makes a FD for a Y1 and with a ITR one fit
Old Jan 29, 2003 | 11:18 PM
turbohonda's Avatar
Default Re: aftermarket gears for B-series cable trannies (DLB1994)
An ITR final drive will not fit in the 90-91 trannies (Y1). You can switch the 4.26 final drive out of the Y1 with a 4.40 final drive from a S1 or J1.
Old Jan 30, 2003 | 07:08 AM
Taloola's Avatar
Default Re: aftermarket gears for B-series cable trannies (turbohonda)
what about aftermarket companies that made FD and gear sets for cable trannies? anyone know the availability on those parts?
Old Jan 30, 2003 | 07:54 AM
here2race-no.b.s's Avatar
Cheaper Yes .....But you cannot buy any replacement syncros or gears other than aftermarket final drives.......
Old Jan 30, 2003 | 10:10 AM
Taloola's Avatar
Default Re: aftermarket gears for B-series cable trannies (here2race-***.s.)
can anyone link me to a place where they offer FD for these trannies.
Old Jan 30, 2003 | 10:15 AM
Pro drive does big $$$ and 1 other i'll see if i can find out who.
Old Jan 30, 2003 | 02:22 PM
red civic standard's Avatar
A few calculations:
J1/S1 versus Y1
First gear: 5.1% shorter
Second gear: 5.5% shorter
Third gear: 5.8% shorter
Fourth gear: 0.6% shorter
Fifth gear: who cares
To find these numbers, I just took the FD multiplied by the gear ratio for a particular gear and compared this number for S1/J1 to the same number for the Y1. Is this the right way to do it?
Old Jan 30, 2003 | 02:24 PM
Default Re: aftermarket gears for B-series cable trannies (red civic standard)
Another thing about the Y1. If you have stock LSD you can't swap out the FD without getting rid of your stock LSD.
Old Jan 30, 2003 | 03:20 PM
1fstcorrado's Avatar
G-force racing makes a Honda gear set. Although i dont think they sell it, they might make it for someone who does sells it. call them. use google or something to search for G-force.
Old Jan 31, 2003 | 05:02 AM
BudaKai's Avatar
Default Re: aftermarket gears for B-series cable trannies (1fstcorrado)
Quaife also makes FD's. I don't know if they make them for your application, but i know they have them.
Old Jan 31, 2003 | 05:29 AM
tony1's Avatar
Quaife fd's can only be used with the quaife gearset. I believe they are about $2800/set.
Old Feb 3, 2003 | 06:51 PM
tractionbar2nr's Avatar
Default Re: aftermarket gears for B-series cable trannies (tony1)
not everyone has a jotech budget...
Old Feb 3, 2003 | 08:42 PM
tony1's Avatar
Default Re: aftermarket gears for B-series cable trannies (tractionbar2nr)
Old Feb 8, 2003 | 09:25 AM
smokey2.0's Avatar
have you done this? did you just use the fd ring from the s1, on the y1 diff?
let me know!
Old Feb 8, 2003 | 11:07 AM
Jared's Avatar
Default Re: aftermarket gears for B-series cable trannies (jtrbocrx)
YS1 is the way to go if you can get one because it uses the new bigger style input shaft and gears, plus, easy to find parts, but make sure you get a GSR YS1 and not LS YS1
Old Feb 8, 2003 | 01:45 PM
BudaKai's Avatar
Default Re: aftermarket gears for B-series cable trannies (Jared)
Beside gearing is there a difference? I prefer the gearing of the Ls. Torque owns.
Old Feb 8, 2003 | 02:29 PM
aut0tek's Avatar
Default Re: aftermarket gears for B-series cable trannies (BudaKai)
I have a 93 LS YS1 don't let anytone fool you they suck like the phantom vacuum cleaner get yourself some short gears and a big 4.6 final drive instead of the gay 4.26 like mine has. It's ghey with a G-H ;-)
Harry
Old Feb 8, 2003 | 03:07 PM
ProTreeCRX's Avatar
is this true? is it possible to use other oem cable final drives with the Y1 LSD (JDM YS1 final inside Y1 tranny with LSD)?
tonyjdm
Jun 6, 2011 04:35 AM
CRXEE8
Jun 19, 2005 01:32 AM
nmhybridog
Oct 14, 2003 09:46 AM
DJCujo69
Aug 12, 2003 09:08 AM
jdmhondageek
Dec 1, 2001 05:24 PM
