P30 with LS/VTEC,safe to run without vafc?
Old Jan 29, 2003 | 12:24 PM
Wong Wonder's Avatar
Default P30 with LS/VTEC,safe to run without vafc?
b16a haed with b18b block and bolt ons
Sonic's Avatar
Default Re: P30 with LS/VTEC,safe to run without vafc? (Wong Wonder)
It'll be fine, but won't yeild as much power as if it were tuned with a vafc
Old Jan 29, 2003 | 01:27 PM
Default Re: P30 with LS/VTEC,safe to run without vafc? (Sonic)
any areas of the rpm range i should concentrate on?
Old Jan 29, 2003 | 01:45 PM
sgT's Avatar
sgT
i would try to get a p72 ecu instead if at all possible.
or get that p30 chipped
Old Jan 29, 2003 | 05:40 PM
Default Re: P30 with LS/VTEC,safe to run without vafc? (sgT)
Whats the difference between a P30 and P72?
Old Jan 29, 2003 | 05:42 PM
lazy bum shaughn's Avatar
P30 is from the B16 I think, P72 is from the GSR(butterfly manifold, different VTEC engagement).
Old Feb 9, 2003 | 07:50 PM
Default Re: P30 with LS/VTEC,safe to run without vafc? (lazy bum shaughn)
I hear some lean backfiring when I let of the throttle.Are you sure it's safe to run?
Old Feb 9, 2003 | 08:01 PM
IDriveHonda's Avatar
A P30 looks for a knock sensor, which you do not have with a B18b block. You might want to consider a chipped P28 for best results.
Old Feb 9, 2003 | 11:45 PM
ATYPR's Avatar
Default Re: P30 with LS/VTEC,safe to run without vafc? (IDriveHonda)
FAmou5
Engine Management and Tuning
Aug 4, 2009 04:49 AM
RHDintegXsi
12
May 21, 2006 04:57 PM
meotch
Aug 31, 2005 08:45 PM
Buckshot
Mar 31, 2003 07:48 PM
