Injector upgrade worth it???????
Old Jan 29, 2003 | 11:21 AM
mugenracer's Avatar
Default Injector upgrade worth it???????
I got myself a set of JDM H22 injectors today (i think theyre 290cc) anyways, i was told by one person that just by dropping them in will do absolutely nothing, whereas another person said that i should see some pretty good gains over the stock injectors. Can anyone tell me for definite before i put them in will they do any good just dropping them in? Would i need to get a FPR too?
Edit: I want to put these in to my JDM integra (B18C - 1994)
[Modified by mugenracer, 8:22 PM 1/29/2003]
Old Jan 29, 2003 | 12:12 PM
altoid's Avatar
Default Re: Injector upgrade worth it??????? (mugenracer)
if its still stock, you'll just run rich (unless your b series injectors are 290), which is not as good as having a stoic a/f mixture. but who knows try it
Old Jan 30, 2003 | 05:37 PM
mugenracer's Avatar
stock injectors are 240cc, anyone actaully done this on their B18C?
Old Feb 1, 2003 | 03:09 PM
mugenracer's Avatar
anyone else have any ideas or actually know??????????
Old Feb 1, 2003 | 03:18 PM
joe_bocc's Avatar
Unless you have upgrades on your engine and are having problems running lean then the H22 injectors will do nothing!
Old Feb 1, 2003 | 03:31 PM
junb16's Avatar
Default Re: Injector upgrade worth it??????? (joe_bocc)
LoL quite true
Old Feb 1, 2003 | 04:01 PM
Desslok's Avatar
Default Re: Injector upgrade worth it??????? (junb16)
If you are bringing more air into the engine(ex. I/H/E), then the extra fuel may help. If you don't need the fuel, you could lose power and waste more gas=$.
Old Feb 1, 2003 | 04:02 PM
Kamin's Avatar
they arent gonna do jack **** except hurt your performance unless you need the fuel. and just dropping them in wont help anything, even if you needed the fuel they would need to be tuned with a vafc. or safc.
Old Feb 1, 2003 | 04:05 PM
joe_bocc's Avatar
If your worried about running lean then get the FPR before the injectors and use that to add the needed amount of fuel. If you keep modding your engine to the point where raising the fuel pressure isn't enough, then upgrade your injectors.
type B16
Oct 5, 2006 04:06 AM
egH22
Mar 16, 2005 12:44 PM
Honda97
Mar 5, 2005 07:32 AM
TypeR0207
Feb 10, 2005 03:42 AM
AzNpRiD3
Oct 28, 2004 06:35 PM
