ECU FUSE location
Hello, i just purchased a AEM CAI and i want to reset the ecu. I opened the fuse box under the hood, but i wanted to know which one is the ecu fuse. Im guessing the one that says "MAIN" is the ecu? somebody correct me if im wrong. Is the MAIN fuse the ecu fuse? Thanks.
DAMN you thread hi-jacker! okay i'll tell u. When i do, lets just try to get these people to tell us the ecu fuse location.
to reset the ecu, disconnect the negative battery terminal. Then, unplug the ecu fuse (thas what im lookin for). THen, step on the brakes a couple of times to make sure that all the electricity has flowed out of the car. Leave the car for about 5 minutes or more. When you come back, plug in the Ecu fuse and reconnect the negative battery terminal. Start the engine and turn off all the electrical devices. Let the car idle for about 7-10 minutes. Turn off the engine. VIOLA! your cars ecu has been resetted. No more questions on resetting the ecu.
pull fuse #13 in the passenger side fusebox for 10 seconds or longer.
resets without pulling the battery wires off
it's not the fuse for the ECU itself, but i think it's the one you want mojo.
Thank you for the reply it was e-z took off the battery(Black Wire). WAited about 5 min. Boom it worked check engine light disappered too.
Does anyone check engine light s goes on and off sometimes
all the fuse 13 does is disable the clock. Nothing else.
its the fuse for the back up power(memory) to the ECU. trust me. this is straight outta the Helms
This is correct, however, may I add that after you put the fuse back in, start the car WITHOUT touching the gas and let it idle for at least 1 minute without giving it any gas.
you can pull the fuse and wait, or you can remove the negative from the battery for like 1 second and you are done..
if you like to pull the fuse, press the brake padel couple of time to release the remaing electrons.
let it idle for 5-10 min.
"Thank you for the reply it was e-z took off the battery(Black Wire). WAited about 5 min. Boom it worked check engine light disappered too.
Does anyone check engine light s goes on and off sometimes"
LOL, sorry to tell you that it doesnt fix your problem.
CEL is not suppose to be on and off, you gotta have something wrong.
try to pull a code and see what it's up with your CEL.
anyway, as far as performance goes, you can be lazy and not reset the ecu,
it will "learn" by itself after sometime
Everything reseted even the Clock, Radio, and Alarm went on. So dat means my ECU didn't get Reseted?
OK i just pull fuse #13 and remove Black Wire Terminal and waited avout 5 min then plau the fuse back in and the Terminal and let it Idle 10 min then shut it off.
Then about 5 min later i went to turn it on than put it in R than i put it in D4 than light came on. ???Y
[Modified by SiRAccord, 4:56 PM 1/30/2003]
Obviously you have a problem. the light keeps turning back on.
get the code from it.
"just because you reset the ECU doesn't mean the code goes away forever
get the code from it."
Well said
OpTiX619
May 14, 2005 10:05 PM
