What Drag Radials to USE??
Just wondering what brand and size D/Rs people reccomend I use? I have a boosted G2 teg with about 220whp, I am not allowed to use slicks unless I get a cage etc
So yeah what size and which brand will be good, car weighs about 2300lbs ..... I don't think we can get Nittos in New Zealand so basically and other brand then them. Any help is appreciated.
well the BEST drag raidals in my (opinion) were the Mickey thompson Competiors... Back in the street racing days we would roll on these with a bottle of VHT, or COKE.they only came is 15 inch and if i recall correctly they were 205/50/15. didnt last long on the street but if you want holding power on the tires theres are
. now there are BFG,NITTO,TOYO,FALKEN which are also better than the reg tires. its peoples preferences. some people swear by one and some people swear by others..!! TRY MICKEY THOMPSONS.
We like the Falken Azenis
BTW...I use BFG's and they hook great.
[Modified by Al Bundy, 12:49 PM 1/29/2003]
falken azenis suck for drag racing, the sidewall is too stiff...i still dont know why people think its a drag tire
I have only have 14inch rims I should have mentioned!! There 5zigen liteweight rims, the M Ts only come in 15s aye?? So what BFGs what size would be best for me, the track I run on has basically no traction, last time I spun 3/4 of the track
Ps what kind of BFG whats the proper name incase I have to order them special..
Thanks for the replys
i used the nitto 245/50/16's and they were ok but you had to really heat them up. I'm trying out the bfg 255/50/16's next.
I want to run like 25psi in them and hopefully they will be a bit like slicks
Smarter than you
A bit OT but would this be a good tire to throw on the back wheels then, or would a different tire be more suited for the job? I'd assume that the stiff sidewall would get the weight off the *** end quicker than running drag radials all the way around.
as for the azenis on the rear of a FWD i dont think its gonna really help or hurt u. the best tire for the rear would be the lightest one w/ the least amount of drag(smallest contact patch and hardest compound) and stiffest sidewall.
[Modified by DIRep, 2:31 PM 1/30/2003]
why would u run drag radials all the way around? unless maybe u r AWD.
Smarter than you
yeh thats exactly what im sayin. i just didn't understand why u suggested drag radials for the rear, that would the worst tire u could run. i just run kumho ecsta's 195/50/15 on the rear and inflate them to 40psi. i dont know if it makes much difference but at least they last forever.
SonicDark
Oct 20, 2001 07:22 AM
