Question about machining a B18c block or vtec blocks !!!
Old Jan 29, 2003 | 09:14 AM
Nix_TEG's Avatar
Default Question about machining a B18c block or vtec blocks !!!
If you either resleave or bore out the clyinder walls will you loose the OIL SQUITTERS ? OR does it depend on how much you bore ??
And what is the angle of the valve releifs relative to the center of the piston ( b series pistons)??
IS it 60 degrees ?? And whats the radius or diameter of the valve reief in the piston ??
I have acess to to a 4 axis CNC milling machine and i was thinking of maching deeper valve reliefs into the piston !! HOW mucher deep do machine shops go into the piston SAFELY !!
Old Jan 29, 2003 | 08:19 PM
Nix_TEG's Avatar
Default Re: Question about machining a B18c block or vtec blocks !!! (Nix_TEG)
anyone????
got wide
Sep 4, 2007 03:55 PM
namm
Dec 8, 2006 08:13 AM
tobe1424
Aug 7, 2006 03:05 PM
douglas_be
Oct 31, 2003 04:15 AM
B18C4-T
Nov 24, 2002 09:30 AM
