Will OBD II ECU advance or retard timing as necessary?
Old Jan 29, 2003 | 08:38 AM
cruzersi99's Avatar
Default Will OBD II ECU advance or retard timing as necessary?
I need to get my car smogged. I am currently running a chipped P28 in my 99 Si with timing in the area of 18 (can't remember off hand). If I put my stock ECU back in will it take care of retarding timing back to stock or do I still need to adjust the distributer?
Thanks,
Cruzer
Old Jan 29, 2003 | 08:41 AM
Chris N's Avatar
Default Re: Will OBD II ECU advance or retard timing as necessary? (cruzersi00)
You have to adjust your 'base' timing via the distributor.
Your stock ecu may have a less agressive fuel/timing map, but you should still retard your timing via the distributor if you are worried about passing the smog test.
MPH's Avatar
MPH
New User
When I switched back and forth with the stock ecu and a chipped one the ignition timing stayed the same.
Old Jan 29, 2003 | 08:43 AM
cruzersi99's Avatar
Default Re: Will OBD II ECU advance or retard timing as necessary? (Chris N)
What are the steps for changing timing again?
I know I am supposed to short out the ECU, but I have forgotting exactly how to do it.
Thanks for the quick response!
Cruzer
Old Jan 29, 2003 | 08:44 AM
Chris N's Avatar
Here is how to adjust your timing.
That link has info on how to jump the service connector, too.
[Modified by Chris N, 11:44 AM 1/29/2003]
Old Jan 29, 2003 | 09:13 AM
cruzersi99's Avatar
Thanks Chris!
Cruzer
JohnnyEF
Feb 10, 2010 06:09 PM
---SPEED-DEMON---
Engine Management and Tuning
Apr 1, 2009 12:14 AM
wilsel
Mar 23, 2005 05:37 PM
Poop111444
Aug 31, 2003 09:05 AM
01PYTypeR#1140
Jul 17, 2001 06:33 PM
