timing belt adjustment
Old Jan 29, 2003 | 08:22 AM
integra6650's Avatar
Default timing belt adjustment
ive searched on this but im having a problem i align cams align crank put belt on tension turn over 6 times itsa off 1/16th of an inch on crank so i redo it at least 15 times and does the same its because theres alittle slack between the cam and the crank. so i try turning over like 50 times and it still 1/16th of an inch off is this ok is this normal or shoulf i have some one do it or is there something thats not in the haynes manual that im missing as of now i have it all buckled up with that 1/16th of an inch error but it wont be started until i get ecu
Old Jan 29, 2003 | 08:29 AM
brcivic411's Avatar
Default Re: timing belt adjustment (integra6650)
slow down there cowboy!!
I fell on the ground because I ran out of breath reading your post!
First hint: use punctuation. It really helps the reader understand what's going on. Most people will take a glance at your sentence and not even bother to read it.
Old Jan 29, 2003 | 08:40 AM
Farnsrocket's Avatar
Default Re: timing belt adjustment (brcivic411)
Ok Speedy, your crank pulley mark may be a little off from the mark on the timing belt cover when the belt is on correctly. The important thing is to make sure the cam marks are lined up with eachother like the manual states.
Old Jan 29, 2003 | 09:09 AM
serious's Avatar
Default Re: timing belt adjustment (Farnsrocket)
yup, when i changed my timing belt the markers weren't lined up exactly, but if i moved the timing belt a tooth in either direction it was way off.
Old Jan 29, 2003 | 09:18 AM
Default Re: timing belt adjustment (serious)
math genius but verbal disaster
00crv
Honda CR-V & Element
Dec 19, 2011 04:11 PM
B18C-Hatch
Sep 5, 2006 07:52 PM
EG civic
Jul 8, 2006 08:02 PM
Shaun
Jun 14, 2006 06:29 AM
98-ls
Mar 19, 2004 06:22 PM
