Which ODB1 ECU
Old Jan 29, 2003 | 04:38 AM
7rrivera7's Avatar
Default Which ODB1 ECU
I'm converting from an ODB0 PR3 to an ODB1. I want to run a Hondata stage 4b. Which ODB1 ECU should I get for my B16a/CRX hybrid?
Old Jan 29, 2003 | 05:12 AM
eg6ajk's Avatar
Default Re: Which ODB1 ECU (7rrivera7)
since you're going to tune your maps you can use P28, P30, P61, P08, p91 ECUs.
most popular being P28 and USDM P30
Old Jan 29, 2003 | 05:22 AM
VTECVillain's Avatar
Default Re: Which ODB1 ECU (eg6ajk)
Either of those would be best
[Modified by VTECVillain, 9:23 AM 1/29/2003]
Old Jan 29, 2003 | 07:22 AM
p-boy's Avatar
Default Re: Which ODB1 ECU (VTECVillain)
you would also need to change your distributor..and add a 4 wire heated o2 sensor and of course the obd1 ecu plugs.. good luck.. hondata can be installed on the pr3 ecu why dont you just stick with your pr3 ecu??
Old Jan 30, 2003 | 08:31 AM
7rrivera7's Avatar
Default Re: Which ODB1 ECU (p-boy)
Basically, to remove the need to run 2 O2 sensors.
craig88crx
Engine Management and Tuning
May 15, 2010 09:39 AM
Novtec4u
May 6, 2009 05:02 PM
Will Albers
Mar 12, 2009 11:20 AM
asc
Aug 14, 2008 08:39 PM
NuclearB18B
Sep 19, 2003 04:15 PM
