JDM B18c Type R with JUN stage 3 cams
Old Jan 29, 2003 | 02:13 AM
BillB's Avatar
Default JDM B18c Type R with JUN stage 3 cams
Running the above set-up + Toda fly wheel, Skunk 2 intake manifold & 68mm TB & a 2 layer head gasket what kind hp/torque should it make on 95octane fuel?
BillB
Old Jan 29, 2003 | 02:52 AM
sgT's Avatar
sgT
Default Re: JDM B18c Type R with JUN stage 3 cams (BillB)
maybe 130 if you are lucky.
dontneed skunk2 manifold
or the 68mm tb.
Old Jan 29, 2003 | 03:18 AM
BillB's Avatar
Default Re: JDM B18c Type R with JUN stage 3 cams (sgT)
The motor is comin from Japan I'm over in the UK so the cheapest way for me to get a gud intake/TB set-up is a Skunk2 + 68mmTB.
Do u mean 130lbs ft of torque? what abt hp at the crank figures im after plz.
BillB
Old Jan 29, 2003 | 07:18 AM
Gong Show's Avatar
No, Steve is trying to say that you dont need the skunk2 manifold. Its just a replica of the R manifold so yours will be fine. And you wont need a TB that big of a bore for the set-up your running.
The only benifits the Skunk2 manifold will have, will be on a GSR or LS(b18-B20)motor. 64-65mmTB should be fine. That money could be used other places.
Old Jan 29, 2003 | 07:51 AM
sgT's Avatar
sgT
It comes with the best intake and TB you could buy. Dont need that crap.
BillB
150-160 crank lbft
Old Jan 29, 2003 | 09:00 AM
BillB's Avatar
The motor is coming from Japan without TB & intake manifold so what wud be my best option to go with?
I can get a Skunk2 intake manifold for £200 ($330) & a 68mm TB for £80 ($131).
Or is that too much any suggestions welcome!
BillB
Old Jan 29, 2003 | 10:04 AM
92TypeR's Avatar
FSAE
The 68mm TB is overkill, even for a JUN3 setup.
The JDM ITR is perfect if you can get your hands on it...should cost less than the 68 also.
Old Jan 29, 2003 | 10:31 AM
sgT's Avatar
sgT
BillB
Stock ITR is like 200
Stock IM and TB is best
JunIntegra
Oct 13, 2003 02:02 PM
spettinger
Jun 23, 2003 09:25 PM
mattcxb18
Feb 4, 2003 01:37 PM
ninjaman
Sep 3, 2002 03:39 PM
J.R.
Apr 30, 2002 05:40 AM
