mtf drain bolt??
which one is it? i know that it is on the passenger side but which one? Also which is the fill bolt? thanx.. oh yah for those following me on the first time clutch install, it should be done by fri. night if the clutch gets here... I want my car back, damn..
It should be the 3/8 inch square the you can find on any 3/8 inch rachet. The fill bolt is either the tranny breather, or the bolt by the passenger side axle closer to the fire wall. I think its a 17mm but could be wrong.
Drain bolt is the shiny one closer to the bottom. It accepts a 3/8" drive...no socket needed.
The fill bolt is the 17mm bolt just above the axle....and a little to the rear of the car...I think. You can either use that or remove the VSS (2 - 10mm or 12mm) and shove a hose down it and slap a funnel on top.
doom26464
Jun 18, 2008 07:10 PM
RCautoworks
Feb 16, 2003 11:16 PM
