Best ECU to use in JDM b16a2 swap?
Old Jan 28, 2003 | 08:59 PM
TurboJesse
Guest
Posts: n/a
Default Best ECU to use in JDM b16a2 swap?
Im wondering what would be the best non-chipped ecu to use for my Jdm b16a2...i have the ecu that came with the swap and i also have the ecu from my old engine,93 sohc vtec automatic...for some reason the car starts up and idles better with the auto ecu??? is it just me? help me im a noob to the B-series.
Old Jan 28, 2003 | 09:12 PM
GTlvr82's Avatar
Default Re: Best ECU to use in JDM b16a2 swap? (Mpir3)
I am changing this b/c i can't post...noooob. I was told by my friend who drives a civic si that his mugen ecu improved his 1/4 times...word of mouth. I didn't see it myself. . I didn't mean to **** anyone off. I am feeling this all out and plan to build a sleeper of my own...no rice.
[Modified by GTlvr82, 10:14 PM 1/29/2003]
Old Jan 28, 2003 | 09:15 PM
jonas's Avatar
no such thing as a "jdm b16a2". maybe you mean SiR-II?
if your block says "b16a2".. then its not JDM and you got ripped off.
mugen ecu? for what? it has a lower vtec point, and higher rev limit.. lower vtec point does NOT equate to more power unless his motor is set up and tuned for it. if its stock, then it will do more harm than good.
Old Jan 28, 2003 | 09:19 PM
976's Avatar
976
New User
Default Re: Best ECU to use in JDM b16a2 swap? (GTlvr82)
TRY THE MUGEN...IT REVS TO 9 GRAND THO...MIGHT WANNA BUILD IT OR YOU COULD BREAK SOMETHING
Aviod this yelling n00b post - of course you will since you didn't ask for aftermarket ecu anyway...
You are running a p30 now correct, I've seen a dyno with a p72 ecu on a b16 is some great increases, however this is kindof hard to believe. More or less it must of been modified as well...
Anyway, the question I'd ask is what do you plan for the engine? Lower vtec engagement, higher rev limit? Are you going to heavily mod your car?
Old Jan 28, 2003 | 10:30 PM
TurboJesse
Guest
Posts: n/a
Default Re: Best ECU to use in JDM b16a2 swap? (w00t!)
Im eventually planning on turbo sometime this spring...Im just not too familar with the honda ecu's and what one is what (Hey im trying to learn, had the car for awhile just never really into honda performance, i do drive a boosted bimmer though )...any help is appreciated
Old Jan 29, 2003 | 12:25 PM
976's Avatar
976
New User
Bump for you, I'd like to know a good non-chipped ECU that will work with a turbo...
If I was you I'd just have your ecu rechipped, member Kenji on this board can do it for you, he'll customize it for you..
Old Jan 29, 2003 | 12:28 PM
jonas's Avatar
you're willing to boost your motor? but you're not willing to upgrade your engine management? LOL.
Hondata.
Old Jan 29, 2003 | 03:11 PM
TurboJesse
Guest
Posts: n/a
Default Re: Best ECU to use in JDM b16a2 swap? (jonas)
Hondata.
Im goin with Hondata when i do turbo the engine...Im asking what to do for now, i have 2 ecu's, p28 and p30, whats the diff. between the 2?
Old Jan 29, 2003 | 03:42 PM
976's Avatar
976
New User
Hondata.
Ah, they are very simular.
However the p28 ecu doesn't not have a knock sensor.
But the p30 does, but it also has the duel butterfly engagement (whatever it's called) which will run better for turbo esp. vtec.
If you want to keep knock sensor, go p30...
Old Jan 29, 2003 | 03:49 PM
function83's Avatar
Hondata.
wrong
p30 does not have dual butterfly capabilities .
a gsr computer p72 has the capability to run secondary runners.
if it was my car id run the p30. Make sure you wired the knock sensor.
also the p28 does not rev high enuf.
on top of that its an automatic which is a no no.
i believe its cuz it looks for the tranny.
[Modified by djhatch, 12:54 AM 1/30/2003]
Old Jan 29, 2003 | 04:19 PM
b16 matt's Avatar
Default Re: Best ECU to use in JDM b16a2 swap? (djhatch)
If your going hondata it does not matter p28 or p30 all map and ignition tables are changed.... I am using a p28 with the s100 and it runs great. 12's all day long with a b16 turbo and 450 injectors 9:1
[Modified by b16matt, 1:21 AM 1/30/2003]
Old Jan 29, 2003 | 05:28 PM
function83's Avatar
Default Re: Best ECU to use in JDM b16a2 swap? (b16matt)
yes u can chip your p28 to run on your b16.
i believe katman can convert an auto ecu to manual.
Old Jan 29, 2003 | 08:13 PM
976's Avatar
976
New User
Thanks djhatch for correcting me. I didn't think mean to give false info...
So how would a p72 ecu run on a jdm b16?
Old Jan 29, 2003 | 09:22 PM
underrated99si's Avatar
P28 with hondata
Old Jan 29, 2003 | 09:27 PM
EK MONEY's Avatar
KENJI! thats all you need to know about ECUs...
Old Jan 29, 2003 | 09:41 PM
fire7882's Avatar
Since the b16 dosn't have the secondary butterflys, probably not good. Someone care to carrect me on this?
Old Jan 29, 2003 | 10:15 PM
Nameless RB26's Avatar
Default Re: Best ECU to use in JDM b16a2 swap? (fire7882)
yep. It'll throw a nice check engine light for your ***, and you don't need that kind of CEL for a manifold you don't even have.
Stick with the P28. Ditch the P30.
The P28 can be automatic, that's fine, but it will need to be modified/chipped to be a manual.
Talk to "kenji" on the board. He can chip your P28 (or he can sell you one). He has a good custom chip (which ALOT of people on H-T use, including me) that will run the B16 fairly well, although you should probably invest in a vtec/air flow controller, or hondata later on.
Old Jan 30, 2003 | 11:04 AM
slcxow's Avatar
Call Kenji, he'll sell you a nicd p28 ECU
Old Jan 30, 2003 | 12:00 PM
jonas's Avatar
Default Re: Best ECU to use in JDM b16a2 swap? (slcxow)
click on my sig for contact info for Kenji
dc2305
May 14, 2010 06:46 PM
Eli Mac 67
Jun 11, 2007 04:45 PM
95cx
Apr 25, 2003 08:07 AM
TurboJesse
Jan 29, 2003 05:30 AM
