D series oil pans all same? even if its 1.5/1.6???????
Old Jan 28, 2003 | 01:34 PM
KevronsEG's Avatar
Default D series oil pans all same? even if its 1.5/1.6???????
i have 91 crx si pan taped for turbo and wnat to put it on my 1.5 jdm sohc vtec
Old Jan 28, 2003 | 08:44 PM
pbomers's Avatar
Default Re: D series oil pans all same? even if its 1.5/1.6??????? (CIV616)
I looked up part numbers for various oil pans and here is what I came up with.
I checked 1997 Civic with 5 speed manual transmission.
-part numbers were different between 1.5 and 1.6
I checked 1995 Civic with 5 speed manual transmission.
-part numbers were the same for 1.5 and 1.6
I checked 1991 Civic with 5 speed manual transmission.
-gave 2 part numbers, but didn't make a reference to which was for 1.5 and which was for 1.6. Seemed odd to me. Just listed both part numbers instead of giving one specific part number for 1.5 and 1.6 like with the other years.
I know this doesn't answer your question, but hopefully will help a bit.
Anybody else got any ideas or know for sure???
Old Jan 28, 2003 | 09:05 PM
USDM 4G VTEC's Avatar
Default Re: D series oil pans all same? even if its 1.5/1.6??????? (TinyCRX)
try checking for the oil pan gaskets
if they are the same pands are same pattern
Old Jan 29, 2003 | 03:13 AM
KevronsEG's Avatar
Default Re: D series oil pans all same? even if its 1.5/1.6??????? (JDM EF9)
i'm more want to know about the size of the pan, i know it will bolt up. but i dont wnat to over oil my motor you know what i mean, put oil for 1.6 an dnot for 1.5 an dhave extra 1/2 quart
Old Jan 29, 2003 | 05:08 AM
Hondasaurs's Avatar
I have a DOCH ZC. It was turbocharged, but my turbo blew a seal, this caused me to put my header back on and replace the oil pan because of the oil return. I used a oil pan from a 1990 1.5 Civic DX. It was an exact match. I would assume all D series oil pans are the same.
Old Jan 29, 2003 | 05:48 PM
seekerONE's Avatar
88-95 oil pans are interchangable for the most part...will bolt up but may have slight issues with exhaust clearance....96-2000 have different bolt pattern due to different oil pump.
turbo*s2k
Nov 3, 2003 11:02 PM
RATEDR
Jun 25, 2002 02:38 PM
