Will the 1.5 sohc CX oil pan fit on a 1.6 sohc Si?
My Si motor's oil pan has a crack in it. I have my CX oil pan lying around. I called Honda and the part numbers are the same to both oil pans, but a tech here says the the girdle is bigger on the Si and the CX oil pan wont fit.
So will it or wont it?
Re: Will the 1.5 sohc CX oil pan fit on a 1.6 sohc Si? (RATEDR)
it should be fine. the oil pans have the same capacity and hold the same amount of oil. moroso makes one oil pan for the 1.6/1.5 sohc and they fit both. the baffle should be the same and the oil pickup is not pan but attached to the block
mr.speaker
09-21-2009 05:52 PM
