clutch / engine noise - help
Old Jan 28, 2003 | 12:23 PM
geminis2k's Avatar
Default clutch / engine noise - help
My GSR is making a very weird noise when I am feathering the clutch to get the car moving in first gear. I can't describe the noise other than it sounding like something is rubbing but the noise is kind of loud, then followed by a small squeak once the car is moving.
Also, if I'm well into gears like 3rd gear and I downshift to 2nd and let the car move without gasing it and I let go of the clutch slowly it sounds like a scratching noise..
I can't duplicate the noises but I'm hoping somebody out there has heard of or had something similar happen to them and found out what it was.. I plan to take it to a mechanic soon but I would like to know what it is b4hand, the clutch feels strong - I bought the car a few months ago so I am not sure what clutch is in the car but many people have told me it is not a stock clutch and it feels like a stage1/2 because you basically have to rev my car a bit to start moving it or it will stall..
Old Jan 28, 2003 | 12:25 PM
1bad-eg's Avatar
Default Re: clutch / engine noise - help (geminiGSR)
Check your motor mounts. Especially the rear one cause those are notorious for breaking.
Old Jan 28, 2003 | 12:51 PM
Kataku2K3's Avatar
Default Re: clutch / engine noise - help (1bad-eg)
Okay the first problem is pretty common... A lot of times if a racing clutch (solid unsprung disk) is not broken in properly you'll get that squeak a lot of the time... Even if you break them in properly they'll sometimes do so... I really wouldn't worry about it because it's just something you'll have to live with... I put an ACT Maxx Xtreme PP w/ 4 puck disk in my friend's GSR/EK... anyways he put ~600 miles on it before stabbing on it and shifting hard just so it wouldn't squeak but it does now... I also just put a GSR into my friend's EG with a ACT Heavy Duty PP and 6-puck disk... He didn't really bother to break it in and that wasn't that big of a deal but it does make that squeak that i'm talking out... As for the grinding sound when you're downshifting I first thought that maybe you throw out bearing was going out but normally it doesn't make a grinding sound.. more of just a light vibration sort of noise.. kinda like dry dirty ball bearings... <- basically what is wrong with a bad throwout bearing... But i think your problem may be the synchros.... At least that's what it sounds like.... Good Luck and I hope this helps.. Peace
Old Jan 28, 2003 | 01:08 PM
geminis2k's Avatar
Default Re: clutch / engine noise - help (Kataku2K3)
thanks for the help
about the downshifting, i didn't mean my gears grind when I downshift.. if I go from 3rd to 2nd (for example) or 2nd to first, goes into gear just fine but when if I slowly left off the clutch I hear some sound.. hehe =/ /shrug.
I guess I'll find out soon if it's a racing clutch or not, plan to spray on it soon let's see how the clutch takes it.
Old Jan 28, 2003 | 01:27 PM
mugenracer's Avatar
sound very like what my clutch sounds like on take off too, the clutch still bites hard so i figure that its the release/throw out bearing. i'll just suffer it till the clutch gives and get the whole lot upgraded then.
slightly O/T i also have a 93 EG civic ESi (D16Y) beater, it has 170k+ on the stock clutch, the throw out bearing has been whining/rubbing/vibrating for almost 45k miles now, but the clutch still works good!
[Modified by mugenracer, 10:27 PM 1/28/2003]
Inextricabledrvr
Oct 22, 2013 10:18 PM
red05
Honda Civic (2001 - 2005)
Nov 2, 2007 07:41 PM
EJ8VTEC
18
Jul 1, 2005 12:30 PM
RefuseRice
Oct 19, 2004 10:16 PM
geminis2k
Jan 28, 2003 02:20 PM
