Grinding into 3rd at a high rpm
my car is grinding when i try to put it into 3rd at high rpm. it grinds when droping gears at about 70 or if im changing from second to 3rd at high rpms. Its only 3rd gear and i was wondering if anyone knew what the problem could be.
Synchro. I have the same problem. I already changed my tranny fluid over the weekend, and it still does it. I am going to purchace 3rd synchro and possibly 3/4 gears.
Try and call the dealership, ask for 3rd gear synchro, and 3rd/4th gears.
I believe the synchro is 70~100 and the gears are like 250~300. I don't know for sure. (i have a friend that works at honda, and they are hooking me the f*ck up) the labour is going to be your main concern unless you do it yourself... all in all...like 800~1000...at the most. I might just cost you like 300 you never know until you ask.
acura wouldn't sell me just a 3rd gear synchro -have to buy 3rd gear set -it's $240 -evans honda specialist said -$250 installation if i bring the tranny, but $250 more if they pull the tranny.
If you have a manual, you shouldn't have a problem servicing your own tranny. Otherwise, the $250 quote seems pretty damn good if you know how to drop your tranny.
You need the 3-4 Synchro.. no need for a new 3rd gear.
Click here
its called the Sleeve set (3-4) and is $158. Not too hard.
#9 in this pic:
Click here
#9 in this pic:
hondafrk505
11
Jul 6, 2006 05:21 AM
RTW DC2R
Sep 14, 2003 06:02 AM
