power door lock problem INSIDE lock...errr
well if it's not one thing it's a motherFather nother...
i have a 2door 92accord, and my driver side lock wont lock if i hit the switch.. but if the door is locked and i hit the switch to unlock it, the lock moves alil bit it tries too... only way i can lock the door from the outside is to stick the key in it and turn it (keyless dont work either on driver side door).. and if i am to lock my driver side door from the inside i gotta do that manualy aswell..
my questoin is, could it be the lock motor or whatever you call it that's fucked up and finally gave out...? that's what i am assuming but i thought i would post it up maybe someone know EXCATLY what is wrong and help me out
Ive have the same problem every so often. Not sure what it is havent had a chance to take the door panel off and have a look in this cold weather. I'll be interested to see if anyone has an answer.
you do have your door closed when you try to lock it from the inside right? hondas dont lock when the door is open unless you have the handle open.
yeah that is true and they still have not fixed it on newer cars as my 94 does the same thing oh well I just have to remember to lock the door every time I get out of the car.....not a big deal...
[Modified by YeuEmMaiMai, 12:50 PM 1/28/2003]
blah.. this ******* sux.. i hope the weather get's a lil more bearable cuz it's too f'in cold to take anything apart... brrrr... any other suggestions'?
as does my 96
honda locks, and window wont ever be fixed
claim to fame
the reason you cant lock your door while its open is cause honda made it so you cant lock yourself out. when getting out of the car pull the handle and press the lock switch all you doors should lock
EG94dude
Feb 16, 2010 05:44 PM
B18Sleeper
11
Nov 1, 2007 06:24 PM
