Surging Idle on my 91 Integra
Old Jan 27, 2003 | 09:27 PM
HuGEN's Avatar
Default Surging Idle on my 91 Integra
Hello, I have own a 2000 Prelude and a 91 Daily Driving Integra. My problem is that my idle on the integra is surging up and down when the car is completely warmed up. Has anybody have the same problem. Any suggestion and the process of what I should do would be greatly appreciated. Please help thanks!
Old Jan 28, 2003 | 04:48 AM
96IntegraLS4DR's Avatar
Default Re: Surging Idle on my 91 Integra (LudeRacer)
Hey there,
My "other" car is 90 Integra.
Your idle is set too high.
Just pull the VAIC (I think that's what its called) and adjust the idle screw
on top of the throttle body.
Old Jan 28, 2003 | 05:10 AM
IC x Prince's Avatar
New User
Default Re: Surging Idle on my 91 Integra (96IntegraLS4DR)
I had this same problem on my car. I had to adjust the TPS, but unless it has to be modified to adjust it. I sent mine to JG a few years ago, and they did the modification for me, so it was alittle easier to do.
Old Jan 28, 2003 | 05:59 AM
evolve's Avatar
If your tach is bouncing at idle, you may have to check your sensors. Got a Haynes manual? Adjusting the idler screw should only work if the tach is surging, not bouncing. Get a ohm-meter and the manual, and say f*** the dealership.
Old Jan 28, 2003 | 06:03 AM
JDM_B16a_Acura's Avatar
Default Re: Surging Idle on my 91 Integra (evolve)
Check your TPS and purge valves, then adjust your idle screw on the back of the throttle body, that fixed my 92 teg like a charm!
Old Jan 28, 2003 | 06:06 AM
evolve's Avatar
Default Re: Surging Idle on my 91 Integra (JDM_B16a_Acura)
Yep,yep
jizzle1981
Oct 25, 2009 07:08 AM
tylertocker
Apr 20, 2008 01:06 PM
axionm1k
Apr 1, 2008 04:04 PM
crzy1208
Aug 19, 2007 07:57 AM
MIKES
Jul 11, 2002 10:40 AM
