ls cams
Old Jan 27, 2003 | 06:13 AM
unknown317's Avatar
Default ls cams
I have your basic intake and exaust and now I am looking for a good set of cams for the ls? Who out there has cams on there ls besides stock and what do you have? Any suggestions for the best set for the street?
Old Jan 27, 2003 | 06:41 AM
94ls's Avatar
Default Re: ls cams (unknown317)
crower
Old Jan 27, 2003 | 08:07 AM
zilverz's Avatar
i have 2 sets of Crower cams ... crower is quality ..
Old Jan 27, 2003 | 08:26 AM
arw321's Avatar
Default Re: ls cams (zilverz)
I have a set of custom ground cams from Colt Cams.
http://www.coltcams.com
I'm very happy with them. Specs are slightly more aggressive than 403's. (More lift, similar duration).
Adam
Old Jan 27, 2003 | 08:29 AM
LsPower's Avatar
Default Re: ls cams (arw321)
How much did it cost for the regrinds? Did you have to send them stock cams?
Old Jan 27, 2003 | 09:07 AM
unknown317's Avatar
whats the redline with the crower 403's?
Old Jan 27, 2003 | 09:44 AM
Brasspremier's Avatar
you'd want new valvetrain if you wanted different redline
Old Jan 27, 2003 | 10:03 AM
arw321's Avatar
Default Re: ls cams (LsPower)
Yes, I sent my cores and he re-ground them to his specs. Email geoff@coltcams.com with any questions you have, he's a great guy and he would be more than happy to help out. BTW, they are located in BC, Canada.
Adam
Old Jan 27, 2003 | 10:34 AM
unknown317's Avatar
Default Re: ls cams (Brasspremier)
when i replace the cams I will also replace the springs and get titanium retainers....so any idea on the redline with the 403's?
Old Jan 27, 2003 | 10:39 AM
illi Adik's Avatar
I dont believe it will be much higher, I wouldnt expect anymore then maybe 500rpms.
Old Jan 27, 2003 | 01:12 PM
evolve's Avatar
What kind of redline are you looking for. As far as I know the 403's are only good up to under 8000rpm. If that's the case the tit retainers and double v-springs won't be necessary. JG has alun retainers for $90 and silcon steel v-springs for $130. For this cost your can send your head to them and get a valve-job done for the for the same cost as the prior. And remember port-n-polish is only an extra 300bones.
Old Jan 27, 2003 | 01:17 PM
unknown317's Avatar
Default Re: ls cams (evolve)
I would like to have a redline about 8000. How about JUN cams? So if i wanted to I could probably go with the crower 403's and not even have to upgrade the valvetrain?....yet.
Old Jan 27, 2003 | 01:21 PM
evolve's Avatar
You know I've been reviewing some selections for cams, also. I have a 90LS. Crane Cams makes some good cams, too. But, if you look closely at the specs there's two cams I think I would prefer over the Comp's. I don't remember the model#'s or the specs-off the top of my head. The Crane's had a great duration cycle, in-between the two lower end Comps, yet slightly more lift. I'm looking at a mild to moderate N/A setup and will not spend too much time past 7500rpm's, so aggressive overlap is not in my list. Just food for thought. Of course dyno-tuning will only be the right means to decide whether my chose would be right.
Old Jan 27, 2003 | 01:22 PM
evolve's Avatar
Well, at 8000rpm, I would recommend it. The JG valvetrain set is good for 8500rpms. It's a great value, IMHO.
Old Jan 27, 2003 | 01:25 PM
evolve's Avatar
I thought the JUN cams were strictly VTEC??? If they make non-VTEC cams give me the part#. yeahhhh
Old Jan 27, 2003 | 01:52 PM
zilverz's Avatar
Im pretty sure they do only make vtec cams
from Crower's website
62401 = 7000+ redline
62402 = 7500+ redline
62403 = 8000+ redline
62404 = 8200+ redline
62405 = 8500+ redline
Old Jan 27, 2003 | 02:38 PM
arw321's Avatar
FYI guys if you are going to be revving an LS to 8000 rpm on a regular basis you might want to look into some bottom end upgrades as well.
Valvetrain alone won't cut it.
Adam
Old Jan 28, 2003 | 06:28 AM
zilverz's Avatar
Adam
you say this from personal experience ?
LaOstha
Aug 3, 2006 09:16 PM
civbeater90
Mar 4, 2003 05:16 AM
JCracer723
Sep 8, 2002 06:07 PM
4U2NV
Jan 14, 2002 07:42 PM
