DOHC Vtec ecu
It will work but obviously the fuel and timing maps will be optimized to run a dohc vtec engine. The vtec engagement point will be not optimal either but this can be taken care of with a vtec controller and some dyno time. I think the P30 and a vafc will be your best bet.
There are going to be a few problems with running a P30 with an SOHC VTEC engine. Assuming your car is wired for a P28, one problem is the knock sensor. The P30 will be looking for one. And when it does not find one, it will flash the check engine light. Then there are the fuel maps. Simply put, they are wrong. Finally, you can do some real damage if you run the motor to the B16A rev limit on stock internals.
As for the PR3, these same problems apply. But you can add to the list a check engine light due to the lack of a second oxygen sensor.
both of the codes are fixable, ground the knock sensor from the ECU and the 2nd o2 sensor wire just add to you existing o2 sensor. But like you said DONT DO THIS!!!!! 8200 on a SOHC will lead to kaboom very quickly. Stick with you P28.
todubbled1
22
Mar 7, 2009 07:12 AM
Magick211
Aug 1, 2003 06:56 PM
ProjectCRXtacy
May 3, 2002 01:17 AM
