vss electronic to manual?
Old Jan 27, 2003 | 02:53 PM
Creamies's Avatar
Default vss electronic to manual?
Okay i got a Electric VSS but my tranny is cable. From searching the archives theres a electronic to manual vss thhat you can buy? is this true? i need to know what i can do to get my speedo working.
Old Jan 27, 2003 | 03:15 PM
TypRice's Avatar
Default Re: vss electronic to manual? (Creamies)
i need the manuel to electronic...if u get help i need it too.
Old Jan 27, 2003 | 03:31 PM
EF-9SiR's Avatar
Default Re: vss electronic to manual? (TypRice)
hey, if you are going to get rid of you electronic VSS...the one with 3 wires, right?....i'll be happy to buy it off you. let me know.
Old Jan 27, 2003 | 04:12 PM
EF_LSVtec's Avatar
What kind of car or cluster are you running on your cable tranny? B-series? I have one for a B16 that includes the speedo cable and clip, Its yours for $75 shipped. Let me know.
Old Jan 27, 2003 | 09:09 PM
Agent#ONE's Avatar
Default Re: vss electronic to manual? (EF_LSVtec)
hes got an obd1 harness wired to the crx
hes now running obd1 ecu and all.
the CEL throws a code 17...VSS
even by installing the cable drawn sensor..the ecu needs to know something correct?
i think it just may be a bad vss, because it is plugged in.
but the speedo still wont work unless he converts back to the cable speedo sensor.
Old Jan 28, 2003 | 02:45 AM
Creamies's Avatar
Default Re: vss electronic to manual? (Agent#1)
Thanks brian.
bump
ps. the guy was stupid, i took off the electronic vss and was ready to put on the manual one, hahah retarded.. the damn thing is sealed off in the tranny. theres is no way i can fit anything biger then a dime in that hole. So i guess im stuck with going electronic vss. now how the hell do i get it working on my stock cluster?!
Old Jan 28, 2003 | 05:15 AM
ricodemus's Avatar
stock cluster needs the cable VSS. The cluster sends the signal to the ECU. If you switch to electronic VSS, you need to use the SiR cluster or GSR cluster that reads the electronic VSS.
[Modified by ricodemus, 9:16 AM 1/28/2003]
Old Jan 28, 2003 | 11:55 AM
Creamies's Avatar
okay, i went to honda and bought the cable line for the stock crx, would it fit on the y1 tranny? it looks like it would but i dont wana open the bag to see it dosent.
Im still confused about this vss thing, someone please set it straight? is there a converter you can buy? are you forced to go either way just by the tranny being cable or hydro?
bump
Old Jan 28, 2003 | 12:26 PM
ricodemus's Avatar
bump
IT HAS NOTHING TO DO WITH THE TRANNY.. It only depends what gauge cluster you are using. The stock cluster in the 88-91 civics can only read speed through a cable operated vss. Some people opt for the SiR cluster, which uses the electronic vss that was already sitting in your y1 tranny. your car is set-up to run the cable, just take the cable vss out of your old tranny and it should work in the y1.
Old Jan 28, 2003 | 06:04 PM
Agent#ONE's Avatar
Default Re: vss electronic to manual? (ricodemus)
then your saying that the vss thats currently plugged in is bad, since the ecu is throwing code 17....the vss code
Old Jan 28, 2003 | 07:19 PM
EF_LSVtec's Avatar
You're getting code 17 because your speedometer is not working...If you can get your 88-91 speedometer to work using a mechanical VSS from your old motor transferred to the Y1 tranny, you should be good to go...But if you decide to use an electronic run VSS, you need an SiR cluster.
Old Jan 29, 2003 | 01:54 AM
Creamies's Avatar
Awesome! I was working on it all night (along with other stuff). Finnaly got it to work. Thanks for all the help guys.
Yodi71
Feb 11, 2019 12:21 PM
zenon8890
Aug 3, 2010 02:40 AM
tico
Apr 14, 2008 08:47 PM
crxdxsir
Nov 13, 2006 09:36 PM
^MikeG
Oct 10, 2004 07:00 PM
