Stripped Wheel Studd?
Old Jan 27, 2003 | 10:54 AM
TypeR 01 886's Avatar
Default Stripped Wheel Studd?
How difficult is it to reaplace a stripped wheel stud on the R? Acura wanted to charge me like a little over 50 bucks for the job. Should I do it my self and does anybody have a howto to do it or simply explain this. I know it cant be that hard.
The main task would be the caliper and brake asm.
He put the lug nut back on for now beucase I am going to have to get that replaced. Is this "safe" for now? BTW: its the rear wheel. Thanks in advance.
Old Jan 27, 2003 | 10:56 AM
sgT's Avatar
sgT
Default Re: Stripped Wheel Studd? (TypeR 01 886)
rear is easier than front. but is still time consuming
Old Jan 27, 2003 | 10:58 AM
apexii's Avatar
I know when I broke a stud on my prelude, it was not easy to change. I had to remove the whole knucke/hub assembly and give to a machinest friend to press out and the new ones in. THere was noway in hell the stud was able to be removed without removing the hub. Considering the brakes are the same, it may be the same scenario.
I'm sure others in here have dealt with this in the past....
Old Jan 27, 2003 | 11:35 AM
Default Re: Stripped Wheel Studd? (apexii)
do I have to get it done sometime soon or can I drive like that. I dont run it at the track or anything.
Old Jan 27, 2003 | 12:06 PM
sgT's Avatar
sgT
integra and civic, you remove the caliper, and the 32mm nut and it comes right out.
Old Jan 27, 2003 | 12:07 PM
vtecvoodoo's Avatar
Future Texas Boy
goodyear/big o tires/etc will do it for half the price at least.
Old Jan 27, 2003 | 12:19 PM
Default Re: Stripped Wheel Studd? (vtecvoodoo)
thanks man, I will have to check that out!
Old Jan 27, 2003 | 01:11 PM
Jack Black's Avatar
And pick up some antiseize while you're at it.
Old Jan 27, 2003 | 01:29 PM
apexii's Avatar
Default Re: Stripped Wheel Studd? (sgT)
Not a surprise that the prelude has to be different...
[Modified by apexii, 5:30 PM 1/27/2003]
streetracer_305
18
Jun 20, 2015 01:59 PM
hightechredneck
Apr 6, 2013 03:18 PM
pinoyboy204
Apr 13, 2007 01:53 PM
Liquidgsr
Aug 9, 2005 10:49 AM
ActiveAero
Sep 21, 2002 01:02 AM
