Back Fire...wtf?
Old Jan 27, 2003 | 10:11 AM
ITR 2K's Avatar
Default Back Fire...wtf?
Ever since my VAFC reseted on me, do to my friends stupidity, my car has been back firing every time I let go of the throttle. Anybody ever have this problem, if so, please help. BTW, I'm running on comptec headers, and exhaust. Can it be possible that I'm running too rich?
Old Jan 27, 2003 | 10:14 AM
DC2R714's Avatar
Default Re: Back Fire...wtf? (ITR 2K)
I have backfire alot but I also run no cat and a 3in exhaust. Are you running a cat? If you are really rich that will cause you to backfire as well. Check your VAFC settings.
[Modified by DC2R714, 7:15 PM 1/27/2003]
Old Jan 27, 2003 | 11:41 AM
Eluder200K's Avatar
backfire is a symptom of running rich. Check your fuel settings.
Old Jan 27, 2003 | 12:08 PM
Philly_NBP_R's Avatar
Default Re: Back Fire...wtf? (Eluder200K)
unless your'e driving an rx-7, then it's completely normal...
Old Jan 27, 2003 | 12:17 PM
underrated99si's Avatar
Default Re: Back Fire...wtf? (Philly_NBP_R)
I dont get back fires but my exhaust farts when i let off the throtel sometimes littel burbels I guess 2.5 exhaust on stock motor is alittle to big I guess
Old Jan 27, 2003 | 01:31 PM
Hooch'n's Avatar
Default Re: Back Fire...wtf? (underrated99si)
I don't have big back fire on my hatch, but I think it has to do with running rich and having not cat and a "strait-pipe". Better then running lean!
Old Jan 27, 2003 | 02:47 PM
Smitdog's Avatar
Default Re: Back Fire...wtf? (Hooch at 8400-RPM)
Old Jan 29, 2003 | 09:23 AM
ITR 2K's Avatar
Default Re: Back Fire...wtf? (Smitdog)
I forgot the setting on my VAFC. I had everything tuned correctly, until it reseted. The car was running just fine, and I had no previous problems. I guess I will have to set everything again on the VAFC. Note to others, don't ever let stupid people touch things that are too complicated for them to understand.
Old Jan 29, 2003 | 12:12 PM
SamC's Avatar
maybe your friend should pay for your dyno session to retune the car
Old Jan 29, 2003 | 12:15 PM
zer0zer0 TypeR's Avatar
Default Re: Back Fire...wtf? (SamC)
backfire scares the **** outta my friends who ride my car, they're like "WTF was that? your tire?"
joe-who chuckles everytime one of his friends shat's their pants from my backfire
Old Jan 29, 2003 | 12:27 PM
TypeR 01 886's Avatar
Default Re: Back Fire...wtf? (zer0zer0 TypeR)
What is the technical anatomy of a backfire, and also is it harmful to the vehicle?
Old Jan 29, 2003 | 12:49 PM
MyYellowHonda's Avatar
New User
Whats that called? If it's not backfire whats the proper jargon for that?
Old Jan 29, 2003 | 01:20 PM
junglistgsr's Avatar
Default Re: Back Fire...wtf? (MyYellowHonda)
backfiring is cool....especially with flames
Old Jan 29, 2003 | 01:46 PM
gary201147's Avatar
Default Re: Back Fire...wtf? (TypeR 01 886)
Backfire occurs when the exhaust gasses leaving the engine are still rich in fuel where, upon high temperatures in the exhaust system, will ignite and cause combustion in the exhuast that shoots out the muffler.
As for good or bad, you are wasting gas and blowing up your exhaust from the inside out! You make the choice...
Oh yeah, back fires kick *** too!
Old Jan 29, 2003 | 01:52 PM
Default Re: Back Fire...wtf? (gary201147)
very well put, that's why alot of those turbo touring cars in japan and on the GT circuit sometimes shoot out flames from the exhaust, lotsa heat + lotsa rich unused gas= flames
Old Jan 29, 2003 | 02:01 PM
itr1244's Avatar
i have JDM DC 4-1 and T1R test pipe and T1R b-pipe and Spoon N1
now and even before when i only had DC and spoon it still made "backfire" sound and now it's even worse... i dont actually see :fire:
i kind of like it
Old Jan 29, 2003 | 03:56 PM
B2FiNiTY's Avatar
Default Re: Back Fire...wtf? (itr1244)
That's because your not backfiring. That is just the exhaust "popping".
Old Jan 29, 2003 | 05:46 PM
SUPERAUTOBACS's Avatar
Default Re: Back Fire...wtf? (B2FiNiTY)
Can u explain what causes the popping?
I have a stock D15 motor with no breathing/exhaust mods done except for having no muffler and i get those popping sounds. I used to think that it was caused by not having a cat, a free/smooth flowing b-pipe and a straight through muffler would do that, but that doesnt seem to be the case...at least with my car. Maybe my cat is hollowed out after 10 years of use
Old Jan 29, 2003 | 05:53 PM
Based on the way u explain this, it means that a motor that is running rich will, under acceleration, be running their exhaust system with burning fuel right?
But i dont see rotaries or turbo GT machines shooting flames under acceleration.
Old Jan 29, 2003 | 05:57 PM
-Whitey-'s Avatar
Default Re: Back Fire...wtf? (SUPERAUTOBACS)
yea back fires are bad ***...my buddys gsr launches huge flames when his car back fires its cool to see ina dark tunnel at night during high r's
Old Jan 29, 2003 | 09:40 PM
Nvious R's Avatar
From: Bitch Slapping Your Ass Around The Twisties n Doin, it Doggy style At a theater near you
Well, first of all, you had fuel problems with it before. When you had your AEM fuel rail on there with the FPR on there, it was fine. It was leaking though. You swapped it back to normal and after my cousin ( the one who destroys type R's ) got his hands on it, it started bogging and backfiring. We changed the spark plugs, it was a little better. Then we swapped out your Moroso Wires and that helped but it still did it on the decel. your VAFC settings haven't really been messed with unless my cousin messed with it. We reset the VAFC to the stock settings. I think you're running too rich on the VAFC settings. I doubt the weather is going bad but change the fuel settings so that its lower on the narrow throttle band and see how that goes. Tune it down a little bit and see how it runs. You have an Air-Fuel ratio meter on your car, put it to use Will. I have your VAFC manual and you said your friend was supposed to help you do it. Try and see what happens. I don't think it has anything to do with the hardware, its just the electronics.
NovaKnowledgeNow
Dec 4, 2014 10:53 AM
motegicivic
25
Aug 6, 2011 10:46 AM
matman4444
Nov 13, 2004 05:20 PM
SHhh__VTEC
Mar 22, 2004 09:07 PM
808style
Sep 20, 2003 07:21 AM
