GSR brake swap? needed parts list?
Old Jan 27, 2003 | 07:20 AM
Justin Jones's Avatar
Default GSR brake swap? needed parts list?
hey... i wanna do a '98 GSR brake swap on a '88 CRX... i've read a dozen or so threads this morning on the subject... but i still have some questions...
i figure i can just unbolt the trailing arms, keep the lines on them and everything... and just bolt 'em up... hook 'em up and use them... but they'll feel weird with the current master cylinder... true?
Can i use the master cylinder from the GSR? Should I?
Next thing is the front... I figure i can just unbolt the knuckles, plug 'em in and go...
Am i wrong?
Next thing is the proportioning valve... Will i need one? Where should i get it?
thanks, any help is appreciated!
Old Jan 27, 2003 | 06:50 PM
iwhichisme's Avatar
Default Re: GSR brake swap? needed parts list? (Turbo Lover)
with the rear trailing arms you can use them as well as the lines, you will just have to changed out the e-brake cables coming form the interior of the car.
As far as the master cylinder goes, you can use one from a 91 civic ex, or 90-93 teg.
what are you getting the front brakes from?
lastly you will need a porp. valve. I beleive one from a 90-93 teg, or the 91 civic ex will work also.
hope thats help
Old Sep 17, 2004 | 08:49 AM
ZhaGg's Avatar
Default Re: GSR brake swap? needed parts list? (iwhichisme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwhichisme &raquo;</TD></TR><TR><TD CLASS="quote">
Is it necessary to use the Civic master cylinder and porp. vakve? What if I have access to a wrecked GSR and can use all of the brake components including the master cylinder etc.
Do the front knuckles bolt right up to the CRX sus.?
Would there be any advantage to using any other sus. components? For instance, would the front sway bar work on the CRX? Rear?
Thanks in advance.
Old Sep 17, 2004 | 08:56 AM
EL Vap133's Avatar
Default Re: GSR brake swap? needed parts list? (the kid 86)
The only knuckles I recommend you use are the 90-93 Teg knuckles or 90-91 EX Civic Sedan knuckles.
Old Sep 17, 2004 | 05:36 PM
ZhaGg's Avatar
Default Re: GSR brake swap? needed parts list? (EL Vap133)
I'm trying it out... If anyone knows for sure that the GSR stuff won't work and that I'll die on the road because of my unsafe vehicle, please speak now... unless you want me to die as a casualty of research...
Old Sep 17, 2004 | 07:12 PM
crexer's Avatar
Default Re: GSR brake swap? needed parts list? (ZhaGg)
you need the 90-93 knuckes or the 90-91 ex knuckles..........you will have wayyy positive camber with the dc knuckles. Also you can you the booster and master cylinder but one of the hard brake lines will need to be reflared to fit and you will need a 40/40 prop. valve
Old Sep 18, 2004 | 09:38 PM
ZhaGg's Avatar
Default Re: GSR brake swap? needed parts list? (crexer)
Ok, so I ask for advice and cry about how I'm going to die... Maybe I should've waited 'til I saw a response before acting... Then again, I'm an impatient idiot. Anyway, I tried it out. This is what I got:
I need to mention that the engine is missing... I'd expect the sus. to drop a little more... I used to hae extremely negative camber though due to the lowered sus. Will I be OK with that? I'll get it aligned after it'a all done and let ya'll know what happened if anyone's interested.
Oh, and the offset on those 7" rims is 35... A little too far out I realize now. Oh, well, they cost me $100 w/tires, so I'm not going tp cry...
Old Sep 19, 2004 | 12:31 PM
ZhaGg's Avatar
the camber's positive huh?
Old Sep 19, 2004 | 02:36 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZhaGg &raquo;</TD></TR><TR><TD CLASS="quote">the camber's positive huh?</TD></TR></TABLE>
Yes. You need DA Integra or '90-91 Civic EX knuckles. The DC knuckles do not have the proper geometry (obviously).
BTW, you have an '83-87 Corolla GT-S and an '88-91 CRX . . . that rocks. IMHO, the greatest '80s FR and FF sport compacts, respectively.
Old Sep 19, 2004 | 03:07 PM
ZhaGg's Avatar
Default Re: GSR brake swap? needed parts list? (Targa250R)
Thanks for the input and the compliments! I'll go get the right knuckles. Where's the best place to get them? Do the local yards in your area totally jack up any Honda parts? (mine do...)
I wish I didn't have to say it, but the GTS belongs to my friend. Can you believe he bought it for $200?! It had been sitting in a church parking lot for a couple weeks. He called the cops to see if it was registered etc. The cops left a ticket and he left a message under the ticket with his number if the guy wanted to sell it... Lucky bastard! It has factory LSD too...
Old Sep 21, 2004 | 10:17 AM
ZhaGg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R &raquo;</TD></TR><TR><TD CLASS="quote">
So are the DA Integra and the '90-91 EX brakes the same as the GSR? Are the GSR rear discs bigger than the CRX's?
Old Sep 21, 2004 | 06:49 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZhaGg &raquo;</TD></TR><TR><TD CLASS="quote">So are the DA Integra and the '90-91 EX brakes the same as the GSR?</TD></TR></TABLE>
They all use the same 10.3" front rotor. DA Integra and '90-91 EX calipers are the same, while DC (non-R) Integra calipers are slightly different. I believe the DC piston is larger, and it takes a different pad (617) vs. the other two (409).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Are the GSR rear discs bigger than the CRX's?</TD></TR></TABLE>
No. The rotors are identical. They also take the same pad (374).
Old Sep 22, 2004 | 09:53 AM
ZhaGg's Avatar
Thanks! Man, how do you guys know all this stuff?
hammergunner
Mar 11, 2009 06:04 PM
whole9
10
Mar 30, 2007 10:00 PM
o5mar1
Jun 12, 2006 07:05 PM
ahbongkadah
Jul 5, 2005 04:44 PM
racekar
Nov 19, 2004 06:00 AM
