missing link question
Do missing links work? I was curious if there's no way around running multiple check valves to the map sensor. A friend told me everyone he knows who had one said they were junk. Thanks
You can use the SMC plus as an electronic check valve by setting the MAP correction to 0% across the rpm range. When you decide to toss the FMU and just use larger injectors, you can set the SMC plus as a forced induction fuel controller. It's a two in one device! HTH
SMC plus
SMC plus
Yeah, they work, but IMHO they're not worth the money. I'm running fish tank check valves from PetsMart that I got for $0.95 a peice, and they're pretty much the exact same thing - just not as pretty. Haven't had any trouble with them yet
Civiclx
12
Jul 26, 2004 02:06 PM
