What should i set my timing at to tune S200b?
Old Jan 27, 2003 | 06:38 AM
BoostedH23a1's Avatar
Default What should i set my timing at to tune S200b?
like the subject says.. 16degrees?
H23 prelude
t3/t4b
550cc injectors
ignition
coil
cams
all other bolt ons..
Old Jan 27, 2003 | 02:22 PM
Default Re: What should i set my timing at to tune S200b? (BoostedH23a1)
up
Old Jan 27, 2003 | 02:52 PM
Smashback's Avatar
I believe 16 degress is stock, so yes. You should manually set your timing to 16 degrees, then the Hondata should be tuned to alter timing based on bla bla bla..
At least that's the way I understand it.
Old Jan 28, 2003 | 04:40 AM
Default Re: What should i set my timing at to tune S200b? (Hatchblack)
up
Old Jan 28, 2003 | 06:27 AM
LEON's Avatar
Set it at stock timing, then retard with boost.
Old Jan 28, 2003 | 11:35 AM
Default Re: What should i set my timing at to tune S200b? (LEON)
so if i set it at 16 degrees when they tune it they will have to move the distrb... if so i have to bring my timing gun.
Old Jan 30, 2003 | 04:33 PM
GruvyTune's Avatar
New User
set it a bit advance using hondata to about 18degrees by adding about 2degrees to the stock 16 mechanical timing advance. run that 2 degrees in all map columns up to about about 5000rpm, then, set the boost columns to slowly retard in increments of 2/lb, 4/lb, 6/lb as you go from 0-11psi then set your 12+psi columns to whatever your 11psi column is.
thats just a little secret i'll let you in on. shhhhh. don't tell anyone about that. the exact numbers are up to you though to figure out with some time on the street and dyno to get your fueling right. the rest i wont divulge.
Old Feb 2, 2003 | 10:07 AM
Default Re: What should i set my timing at to tune S200b? (GruvyTune)
what the hell did u just say? ahah... i think i got ya.. i didnt know it was a BTR to sweet
Old Feb 2, 2003 | 10:32 AM
DeepSi's Avatar
Your tuner should have all the equipment already. Also i think Hondata controls the timing in a table, and dont need to mess with the distributor. Correct me if i am wrong.
Old Feb 2, 2003 | 10:37 AM
VaporTrail's Avatar
New User
H23 prelude
t3/t4b
550cc injectors
ignition
coil
cams
it really doesn't matter, you can set your base timing to 2 or 200 degrees, just make sure that the tuner inputs that information into Hondata, it will adjust the maps accordingly.
Old Feb 2, 2003 | 11:27 AM
Default Re: What should i set my timing at to tune S200b? (VaporTrail)
aight thanks
trinib20
Dec 29, 2014 06:33 AM
BoRiCuA
Aug 15, 2008 02:27 PM
turbo boost
Apr 15, 2008 04:06 AM
turbotime
Oct 2, 2005 11:11 AM
FBP Si 2000
Jun 11, 2003 01:54 PM
