oITR snychros/gears in a GSR tranny
Old Jan 27, 2003 | 03:44 AM
IC x Prince's Avatar
New User
Default oITR snychros/gears in a GSR tranny
I searched and didn't find the answer I was lookng for. my 3rd gear is starting to grind into third...(suprise from a B-series tranny). I was going to replace the 3rd gear sychro, and i comes in a set 3rd gear syncro and 3/4 gears. Is it bad to put the 3/4 gears from a ITR into my GSR tranny? It was sugested that the 1/2 gear are long, and the ITR 3/4 gears might be to short. should I replace it with GSR gears or go for the ITR? TIA.
Old Jan 27, 2003 | 05:18 AM
stick's Avatar
Default Re: oITR snychros/gears in a GSR tranny (UltraPrince)
well if ur gonna stay all motor, go for the ITR gearing.
i think first gears are the same but change 2-5. ITR gearing is shorter
so accelerating will be more noticeable than ur GSR gears.
might as well get a LSD while ur at it too.
Old Jan 27, 2003 | 05:32 AM
New User
Default Re: oITR snychros/gears in a GSR tranny (stick)
thanks Stick, but you don't think that the ITR 3/4 gear will be too short for the 2 and 5 of my GSR? I know it sounds kinda dumb, but someone mentioned it to me and it just made me think...I might be worried about nothing.
also, if it is just the 3rd gear synchro, would i even need to replace the gears? and if I buy from the dealership, does it all come together, or can I just buy the snychro by itself? sorry for the million questions guys.
Old Jan 27, 2003 | 07:46 AM
New User
ttt
Old Jan 27, 2003 | 08:29 AM
andrewM's Avatar
i dont know the prices or how well ur idea will work, but it seems to me u would be better off if u just swapped out the whole trannsmission with an itr one. shorter gearing and lsd. i would imagine that mixing and matching gears would not b the best idea
Old Jan 27, 2003 | 08:59 AM
stick's Avatar
yes u get each seperate gear
go talk to bob case. works at hall honda/mitsu (he is on the mitsu side) he was my hook up when i lived there.
no i dont think 3/4 will be too short for 2/5 but thats me. u can just to the synchros for third and be done with it.
Old Jan 27, 2003 | 09:09 AM
New User
thanks stick, I think that is mainly what I was conserned with. if I caould just replace the synchros.
Old Jan 27, 2003 | 09:39 AM
StinkyTofu's Avatar
The ITR gears are shorter, but the GSR gears are spaced closer except for 1st-2nd gear. Get a JDM final drive and a LSD and you could have a tranny just as good, if not, better than the ITR tranny.
The problem with buying an ITR tranny is that it costs a buttload from the dealer. If you want to buy it used, theres always that "risk" that it might have problems. In which that case, you will have to tear open the tranny casing and put labor into it. If you're gonna do that, might as well just build your current tranny.
I don't see what the problem would be with mix-matching gears. If you look at the +'98 Spec JDM ITR tranny, it has ITR gears 1-3 and GSR 4-5. Theres a pretty big drop in RPM when shifting 3-4 though.
[Modified by StinkyTofu, 10:39 AM 1/27/2003]
OH_1fstgsr
Transmission & Drivetrain
13
Jul 19, 2011 09:32 PM
rodimus
23
Sep 26, 2003 09:01 AM
rodimus
Sep 22, 2003 01:31 PM
IC x Prince
Jan 27, 2003 08:02 AM
JDMEMM
Oct 24, 2002 10:57 AM
