Help with tint
Old Jan 26, 2003 | 05:07 PM
ridnmyhonda's Avatar
Default Help with tint
i bought my integra with blue tint and want it off. What is the easiest way of going about this? Thanks
Old Jan 26, 2003 | 05:19 PM
GS-Rcivic's Avatar
Default Re: Help with tint (ridnmyhonda)
peal the tint off then use GooGone to get rid of the glue.
Old Jan 26, 2003 | 05:58 PM
Default Re: Help with tint (GS-Rcivic)
any other suggestions
Old Jan 26, 2003 | 06:04 PM
gumbii's Avatar
scope this out kid..... get some black yard trash bags..... those big ones... and get a spray bottle with good soap and water..... i like to use dawn..... make it extra soapy.... cut up the bag... and spray the window, grab a big piece of the plastic bag... and stick it on thru the inside of the car.... then just let it sit under the sun... the hotter it is the faster it will work.... if the soap starts evaporating.... spray more soap under the bag.... after about five or ten minutes, peel off the bag and carefully try to peel off the tint..... it should leave no glue residue.... if it was good tint....
Old Jan 29, 2003 | 09:37 PM
freeplay's Avatar
Default Re: Help with tint (gumbii)
"blue window tint "
Andrew-If I remember right, you said you like my tint the other day when I was parked outside of you house. Then you bought my car!!!! WTF? So you like it but it's dumb?
Old Jan 29, 2003 | 11:42 PM
XxDemonxX's Avatar
Default Re: Help with tint (FreeplayNA)
bwauahah...blue window tint...cant laugh i almost got red tint, i think it looks pretty clean. But i think red an black looks way cleaner, props for blue. Goo-Gone should do it but be careful..noting sharp
Old Jan 30, 2003 | 02:56 AM
Clean91B18A1's Avatar
Default Re: Help with tint (XxDemonxX)
Just peel the old tint off and use 409 or Simple Green to remove the glue.
Spray it a couple of times and let it sit. Then use a razor blade and a little concentrated dawn with water to scrape it off. It should come right off. Then just clean up the mess.
Old Jan 30, 2003 | 04:46 AM
ebelp's Avatar
Default Re: Help with tint (4DrSlushBoxTeg)
Just take a razor to it with some Windex and scrape. It comes right off. Oh yeah, beware, if you peel tint off your rear window, your defroster will be terminated.
Old Jan 30, 2003 | 06:56 AM
Lewie's Avatar
I'm here for the gangbang!
Default Re: Help with tint (ebelp)
use a razor to lift the edge then just peel away...then use goo gone....on your defroster you need to cut along the defroster lines and then peel or else you will f up your defroster
Old Jan 30, 2003 | 11:58 AM
eccentric.ek's Avatar
pay to get it off! lol easy
Old Jan 30, 2003 | 12:06 PM
elwood's Avatar
bwauahah...blue window tint...i think it looks pretty clean. But i think red an black looks way cleaner, props for blue.
Tints are clean now? Somone please fill me in. HELP!
1993ludevtec
Mar 22, 2004 03:19 PM
JdmLsPwr425
Mar 10, 2004 07:34 PM
quik2kSi
Jan 3, 2004 11:32 PM
yellowbuffalo
Aug 16, 2003 01:33 PM
integra15
Aug 9, 2003 12:28 AM
