Please help diagnose problems! *::PICS::*::VID::*
Old Jan 26, 2003 | 04:25 PM
legendboy's Avatar
Default Please help diagnose problems! *::PICS::*::VID::*
Here is the story https://honda-tech.com/zerothread?id=396219
I thought I had it fixed. I put my car back together, completely N/A and it won't rev past like 3000RPM and it stumbles when you try to rev past that. It idles like a beauty now but definatly far from running ok.
My plugs are all black with white on the electrode. No idea what that means. There all the same. I just did another Comp. test and I got 155-160-160-160
[Modified by legendboy, 11:23 PM 1/26/2003]
Old Jan 26, 2003 | 04:31 PM
bretx0r's Avatar
Default Re: Please help diagnose problems! *::PICS::*::VID::* (legendboy)
white specs mean detonation... u might want to try your timing, or maybe u hooked up a sensor wrong
Old Jan 26, 2003 | 04:35 PM
legendboy's Avatar
Default Re: Please help diagnose problems! *::PICS::*::VID::* (bretx0r)
The timing is at 16 Degrees and there are not sensor hooked up wrong, I've checked 10 times
It almost seems like limp mode. but no cel's
[Modified by legendboy, 6:38 PM 1/26/2003]
Old Jan 26, 2003 | 04:51 PM
bretx0r's Avatar
change your plugs and see if your injectors are even getting a signal. using these little light things u plug into the harness (i forgot the name)
Old Jan 26, 2003 | 04:56 PM
lazerus's Avatar
after listening to it for a bit... it doesen't sound like that to me anymore... something is whack dude. lol
what is your fuel pressure?
[Modified by lazerus, 6:00 PM 1/26/2003]
Old Jan 26, 2003 | 05:14 PM
Farnsrocket's Avatar
Default Re: Please help diagnose problems! *::PICS::*::VID::* (lazerus)
What is your fuel set up now??
Old Jan 26, 2003 | 05:22 PM
done's Avatar
Default Re: Please help diagnose problems! *::PICS::*::VID::* (Farnsrocket)
is that your cel on? your car might be running in "safe mode", reset ecu
Old Jan 26, 2003 | 05:38 PM
inspyral's Avatar
Are you sure your TPS, MAP, and IACV are hooked up right? All three of those plugs look the same, and will interchange.
Old Jan 26, 2003 | 05:43 PM
BudaKai's Avatar
Default Re: Please help diagnose problems! *::PICS::*::VID::* (inspyral)
Maybe a bad sensor?
Old Jan 26, 2003 | 05:46 PM
legendboy's Avatar
Default Re: Please help diagnose problems! *::PICS::*::VID::* (tzsir)
Put in some new plugs, runs good as new
DDream
Sep 25, 2012 07:07 PM
wastedyouth2542
Sep 22, 2009 02:21 PM
Layziebtnh055
Aug 23, 2004 05:06 PM
The Brown Kid
Oct 23, 2003 03:20 PM
