What a/f gauge do u guys use?
I was just wondering what a/f gauge you guys are using and what do u think about them? Also what does a wideband o2 senser do? Thanx in advance.
a/f gauge = pretty lights, basically a rich lean meter. black and white
wide band sensors give you an accurate reading of the a/f mixture.
thats what i use
thats what i use
thats what i use
thats what i use
ok i have a dumb ? but how does the wideband display the mixture or is it only accesed on the dyno.
oxygen sensor
This is actually who I am looking at geeting one from. Datalogit in Austrailia recoomnd them as well.
Ok i see they are in Austrailia so does anyone in the U.S. carry this one and are there others which are as good or better. I dont meant to be a pain; i just want to get all the info possible. What is datalogics website?
[Modified by ITR-862, 6:37 PM 1/26/2003]
I have no problem at all ordering from Aus. I was just wondering if any companies in the U.S carried these or any other ones. I am now searching like i should have done in the first place but thinks for the info guys. You are always a big help.
The two most common around here are the TechEdge unit, and the one from FJO...
Check here for some more info/comparisons:
https://honda-tech.com/zerothread?id=386534
the more hp you make, the more need you might find for one of these.. - Australian kit is more reasonably priced and its already assembled, theres one DIY in U.S for much less money, but you have to do more assembly..
The Autometer A/F Guage really doesn't work.
I guess it looks cool though
The Aussy DIY Wideband is a really nice unit. Customer service is great. It only took 4 or 5 days to receive my Wideband O2 sensor when I ordered it back in May.
I have the Techedge intergrated into my AEM EMS and the two combined can do DataLogging as well as Automatic Fuel Mapping. Which has made tuning on the fly real easy.
[Modified by Christian, 5:29 PM 1/28/2003]
...... The Aussy DIY Wideband is a really nice unit. Customer service is great. It only took 4 or 5 days to receive my Wideband O2 sensor when I ordered it back in May.
FWIW, Im gonna be running a Halmeter gauge once I get the ECU installed...
i have got a defi "d-gauge"
a lot more acurate then autometer, because it reads in numbers
As long as the car is tuned well, an a/f gauge is basically useless. That's all.
[edit]
As sgt (and many others!) have already said: an a/f gauge without a wideband is just pretty lights.
[/edit]
[Modified by JohnnyK, 7:43 PM 1/28/2003]
[edit]
[/edit]
An in-car wideband O2 is also pretty useless in a mild to moderately modded car especially without a stand alone tuning device.
[Modified by Christian, 8:22 PM 1/28/2003]
