OT: some misc. question about 6th gen coupe
i need some info about my fattie accord coupe 2002
1)weight
2)vehicle number name thing(dc2,FD..those kinda ****)
3)for those did a bypass for coolant line for tb, please show me
where is the other line are at..the "return" line.
[Modified by iam7head, 10:13 PM 1/26/2003]
1)weight
1)weight
1)weight
2. check vin number
I don't have any pics, but I did the coolant bypass. pull off your CAI. on the bottom of the TB right below where the intake attaches are 2 rubber lines going into the TB. just pull them off of the TB and attach them to each other. I used a brass fitting from the plumbing dept at home depot. I forget exactly what size it was but it has barbs on both ends. unlike the older accords, the F23 doesn't have a FIAC valve on the bottom of the TB that needs to be blocked off.
Don't worry about pulling off the wrong lines. the only rubber lines going into the TB are either coolant or vacume lines, so you should be able to easilly tell the difference when you pull them off. and there are only 2 coolant lines.
so you saying the "supply" and "return" lines are both on the left side of the tb,
under the bufferfly thingie right?
faran
Feb 4, 2013 05:00 AM
Benard
Aug 4, 2005 02:29 PM
igo4bmx
Apr 8, 2004 07:25 PM
thanks alot..
