Short Shifter Question
most short shifters are a bit shorter than the stock shifter... i have a dc and it sits about 1"-1 1/2" shorter with the stock ****... if i put a **** on that doesn't have threading all the way to the top, then it will sit a bit higher... but the main function is to shorten the throws and the dc does just that... i love it
on most short shifters, the part above the ball (pivot point) is the same length as stock. however, the part below the ball is longer which gives the same effect as a shorter top. so as stated above, it looks the same length but allows for less movement of the stick to shift.
2k1_ITR_0736
31
Jul 20, 2002 08:41 AM
