b16 wont start?? please....
Just installed b16a ina ed9. Wont start. Doesnt seem to be getting spark, new plugs/wires, replaced coil, and cap..... What else could it be??? There are two grounds hooked up, one on the right side (facing the motor) and the other on the tranny, should there be anymore?? What else could be causing us not to have spark?? The DAMN thing wont start!!! Pleaseeeeeeee help....
that is your prob ...make sure to check the ground on the starter...that was my prob..also on all your grounds make sure that the surface is clean and free of paint....
Not getting fuel to engine, it seems grounded, tested it, and it turns over all day long, so the ground shouldnt be a problem.... just no fuel/spark.....
pr3 ecu, should that red light be on or off, other than flashing codes, which it is NOT doing.... the light is neither on / or flashing??
Havent wired up additional 4 wires yet, would that make a difference??/
how about the ground on the t stat housing?
what is this t stat housing? where is it??
the thermostat houseing is....follow the lower radiator hose. the thing that is goes into is the thermostat houseing. make sure it is grounded. make sure the starter is grounded, and make sure the valve cover is grounded
RussHondaCRXVtec
Dec 17, 2003 10:40 PM
RussHondaCRXVtec
Dec 16, 2003 09:37 PM
