upper ball joint
Old Jan 25, 2003 | 03:24 PM
turbo sol's Avatar
Default upper ball joint
my driver side upper ball joint is bad. I read in my book that it is an "intergral" part of the upper control arm and the whole control arm needs to be replaced? is it possible to change out the upper ball joint? or should i buy new upper control arms. I was thinking abou the ones that let you change camber bc i am going to drop the car soon. thanks for any help
Old Jan 25, 2003 | 03:27 PM
PaImportTuner's Avatar
Default Re: upper ball joint (turbo sol)
you must change the whole upper control arm with balljoint.
i just did my left and right tie rod ends, upper and lower driver side ball joints... got it done for $80
[Modified by PaImportTuner, 12:28 AM 1/26/2003]
Old Jan 25, 2003 | 03:29 PM
turbo sol's Avatar
Default Re: upper ball joint (PaImportTuner)
part numbers? cost?
Old Jan 25, 2003 | 03:31 PM
I got the upper A arm at the junk yard for. $25 total. like brand new.
Old Jan 25, 2003 | 03:33 PM
tie rod ends andlower balljoint i got for like $100 new at pepboys.
only the lower balljoint is seperate from assembly.
Be prepared to pay $125-140 for a NEW upper control arm with balljoint.
[Modified by PaImportTuner, 12:34 AM 1/26/2003]
Old Jan 25, 2003 | 04:12 PM
Tyson's Avatar
no, you cant just buy the stock balljoint without having to pay for the whole A-arm. $90 from majestic. however, you can buy aftermarket balljoints that will replace just the balljoint and provide adjustability from http://www.specprod.com/
[Modified by Tyson, 5:13 PM 1/25/2003]
Old Jan 26, 2003 | 10:01 PM
Toptul_Honda's Avatar
New User
Default Re: upper ball joint (Tyson)
do i only have to use CRX upper arms or can other arms from other cars work?
Old Jan 26, 2003 | 11:12 PM
igone916's Avatar
Default Re: upper ball joint (G2-Rex)
The ball joints on the control arms can be removed if you have a 90-91 ef...only the 90-91 ef's ball joints can be pressed out...the 88-89 ef's ball joints are welded to the control arms...
Old Jan 26, 2003 | 11:59 PM
tyler's Avatar
Default Re: upper ball joint (igone916)
specialty products company 35 dollars part# 67075
Old Jan 27, 2003 | 09:18 AM
turbo sol's Avatar
Default Re: upper ball joint (tyler)
since i have an 89 then i am assuming i need to either;
1. get new arms from majectic or soemplace like so.
2. go to a junkyard and get a set up 91 UCA's and use SPC ball joints to put in, (or use the mif they ar good?
3. are 92-93 UCA's usable or not?
Old Jan 27, 2003 | 09:39 AM
turbo sol's Avatar
i called spc performance and they quoted me
$60 each for the 67075
$160 each for 67320
$140 each for 67320
if you know of a place to get teh 67075's for 35 each, let me know. I was thinking about going with one to adjust for camber, but i am not goign ot have a slammed car, so i should be fine.
Old Jan 27, 2003 | 10:51 AM
New User
is it possible to use 90-91 arms on an 88 crx without having to change anything else connected to it?
Old Jan 27, 2003 | 11:40 AM
Frosty_spl's Avatar
i need to change my upper too, its around 75 bucks at autozone.
Old Jan 27, 2003 | 12:56 PM
New User
Default Re: upper ball joint (Frosty_SPL)
whats autozone? are those american prices?
and are they new pieces? or used?
[Modified by G2-Rex, 2:24 PM 1/27/2003]
Old Jan 27, 2003 | 01:08 PM
keithv's Avatar
autozone is a car parts store and i am 99% sure frosty's price is in USD.
Old Jan 27, 2003 | 01:24 PM
New User
Default Re: upper ball joint (breaka_1_9)
what i meant is. is it an online auto parts store or a local place near wherever you live?
Old Jan 27, 2003 | 01:30 PM
crux131's Avatar
Autozone is a chain store. I believe you can order from there web site though.
www.autozone.com
Old Jan 27, 2003 | 05:31 PM
turbo sol's Avatar
Default Re: upper ball joint (131)
i just found this site:
http://www.k-mac.com.au/makes/honda.htm
they have a nice set up but it is about 370 usd. I think i am just going to get new ones from auto zone 70 each, new balljoint, new arms, the whole shooting match. .
the junk yards want 35 each, and then i would have to pay to have it pressed out and pressed in, not to mention the cost of the new ball joints. in the end its not worth it, ball joints are 50 just by themselves!!
Old Jan 27, 2003 | 05:40 PM
New User
is it the "Perfect circle?"
also are they front or rear? i have an 88 and i heard that they cannot be pressed out
anyone have pics?
[Modified by G2-Rex, 6:43 PM 1/27/2003]
Old Jan 30, 2003 | 09:03 PM
New User
anyways i just bought some used upper arms looks like they were replaced. The ball joints are in good condition.
I noticed that there is a c-clip that can come out. Whats that for?
I want to put ES boot ends on it and want to know how i can replace the rubber
Old Jan 30, 2003 | 09:21 PM
ProTreeCRX's Avatar
70 bux each for a new upper control arm with ball joint?
Old Mar 3, 2003 | 05:48 PM
turbo sol's Avatar
Default Re: upper ball joint (MnC CRX)
yeah
Old Mar 3, 2003 | 08:05 PM
redzcstandardhatch's Avatar
something different
thepartsbin.com has them for like 60 bucks apiece, i bought a set a few months ago, and i am really happy with them.....they fit perfect and seem to be built better than factory. honda wants like 150 apiece for them.........that sucks
Old Mar 3, 2003 | 08:12 PM
bryant's Avatar
$160 each for 67320
$140 each for 67320
Don't go with what SPC says. They rip you off if you order direct through them. Ask SPC for the the closet shop to you or even some that are in the area. And call those shops for price quotes. They will be cheaper.
[Modified by Bryant, 10:17 PM 3/3/2003]
coojoe59
Jun 9, 2008 05:37 PM
XstouterX
Jan 9, 2006 10:31 PM
staticrex
Nov 3, 2005 12:22 PM
DaChoZn1
Jul 30, 2004 02:23 PM
